Breaking disk encryption with RAM dumps
posted Feb 21st 2008 3:12pm by Eliot Phillips
filed under: pcs hacks
If you haven’t gotten a chance yet, do watch the video of this attack. It’s does a good job explaining the problem. Full drive encryption stores the key in RAM while the computer is powered on. The RAM’s stored data doesn’t immediately disappear when powered off, but fades over time. To recover the keys, they powered off the computer and booted from a USB disk that created an image of the RAM. You can read more about the attack here.
How can you reduce this threat? You can turn off USB booting and then put a password on the BIOS to prevent the specific activity shown in the video. Also, you can encrypt your rarely used data in a folder on the disk. They could still decrypt the disk, but they won’t get everything. I don’t think this problem will truly be fixed unless there is a fundamental change in hardware design to erase the RAM and even then it would probably only help computers that are powered off, not suspended.
The potential for this attack has always been talked about and I’m glad to see someone pull it off. I’m hoping to see future research into dumping RAM data using a USB/ExpressCard with DMA access.
Recent Posts
Reader Comments
hack a day serves up fresh hacks each day, every day from around the web and a special how-to hack each week.
send us your hacks
hacks
resources
rss newsfeeds
powered by wordpress
Most Commented On (30 days)
Recent Comments
