Radio Controlled Sphere
[youtube=http://www.youtube.com/watch?v=8twa_zqT9Vg&feature=player_embedded]
[prabbit22m] has written an instructable on how to build a radio controlled sphere. The mechanism is fairly simple, with one drive motor, one servo and a gyro for stability. To turn, the servo shifts the center of gravity off to one side. You can see that the system works pretty well in the video above. If it didn’t have that gyro, it would be insane, believe us, we’ve done our own experimenting. If you like this, but want more features, check out this one that has a camera and takes pictures wherever it goes. We can’t forget Swarm either. The autonomous swarm of robot spheres. Of coarse [prabbit22m] might have the best idea of all. Dress it up as a regular ball to mess with people.
18 thoughts on “Radio Controlled Sphere
  1. now that is exactly the thing i designed in like 7th grade the security cam robot from pop sci was close and the xkcd had an interesting way of putting on the camera but finally some one used there brains and put in a gyro. when i thought of it though i had intended to use it as a battle bot with a much larger well… everything that way i could maybe idk crush it? im not sure but i still have the plans i drew up years ago looks almost exactly like that (though much bigger)
  2. I’m sure your local homeland security place has an outside parking place too, and/or a front entrance, you will always have people doing short visits, and besides, you want to be some distance away and let the ball do the approaching, also you should cover it in kevlar probably.
Leave a Reply to DjoDjoCancel reply
