d-touch tangible drum interface
yes, drums are tangible. We know. What this is, however, is a tangible interface that is a drum machine. The software is freely available for download, after registration. For hardware, all you need is a webcam, a computer, and a way to print out the pieces. D-Touch is cross platform which is very nice. Please note that the software will not run until you activate it by putting in your user account from their site. If you like this project, you might also get a kick out of the Go Sequencer.
Comments
  1. Jeff says:
    Cool idea. I think TrackMate does it better since it records the rotation of the pieces as well which provides more information. For example TrackMate can set individual volumes of the drums.
    http://trackmate.sourceforge.net/
  2. BigD145 says:
    Wooden blocks would be much easier. Just print and glue to a side.
  3. BigD145 says:
    you know what? on that note, why not just use dice? a d6 has pips that should be big enough.
  4. I just have to say wow that kind of stuff is right up my alley.
    Thank you,
    Sunglasswhore
  5. enrico says:
    Thanks for the post and the comments!
    BigD145, if you try the dice or wooden blocks setup please send us pictures!
    Jeff as far as I understand TrackMate is a toolkit, the d-touch drum machine is an actual application.
    By the way the drum machine is based on libdtouch which is an open source framework, code available on http://sf.net/projects/libdtouch , but not yet nicely packaged (we’re working on that, we’ll post updates). libdtouch provides angle and size information, but the drum machine UI simply does not use that. In the near future we’re planning to release another application which actually uses the angle.
    Enrico
  6. enrico says:
    The d-touch sequencer is finally out. Free just like the drum machine from http://d-touch.org/audio
    With the sequencer you can see the rotation control in action.
    Please try it and let us know what you think!
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
