Wine cask sensor suite
posted Aug 4th 2010 1:00pm by
filed under: chemistry hacks
As part of his Master’s dissertation [Salvador Faria] built a sensor suite for wine monitoring. He needed to develop a method of tracking data inside the wine cask during the vinification process. What he came up with eclipses the wine cellar temperature monitors we’ve seen before.
He picked up pH, temperature, carbon dioxide, alcohol, and relative humidity sensors from familiar vendors like Seeed, Parallax, and SparkFun. His original idea was to develop a floating probe that housed the entire package but he had quite a bit of trouble getting everything inside and maintaining buoyancy. The solution was a two-part probe; the stationary portion seen mounted on top of the cask houses the microcontroller, RF 433 MHz transmitter, and the gas sensors. Tethered to that is a floating probe that measures pH and temperature. Data is sent over radio frequency to an HTTP POST server every minute.
15 Responses to Wine cask sensor suite
  • Brad Hein says:
    In 2010 Skynet took over. Then they got drunk on wine and the humans took control back.
  • don says:
    Oh man. This is the start of a great thing.
    It just need to be used for beer.
  • Elias says:
    If he is going to submerge that rusted shit above the PH probe, as seen here: http://middlewaresensing.files.wordpress.com/2010/08/100802220003.png , I’m pretty sure the wine will not be good for human consumption.
  • Matt says:
    @Elias,
    My guess is this is a working prototype, and the final version will be milled out of 18/8 or something similar that wont add off flavors… Good point there though…
  • Patrick (not the right-wing one) says:
    Elias: The outside can be rusty and the inside may still be pristine. It all depends on the environments inside and outside the pipe. Having worked under a lot of disgusting sinks and bathroom fixtures, I can tell you from experience that the outside of a pipe is not always a good indicator of what’s inside.
  • UltimateJim says:
    A little iron never hurt anybody.
  • nave.notnilc says:
    @Elias
    way worse in our water systems :P
  • blar says:
    How do you keep the pH probe calibrated?
  • Elias says:
    Guys, I’m not sure what water systems have to do with this, this is not a pipe with something going through the inside.
    Looking at this: http://middlewaresensing.files.wordpress.com/2010/08/100802215948.png the whole bottom part is submerged.
    But as Matt mentioned this is probably just a proof of consept.
  • fartface says:
    Those PH probes have a solution in them that leaches out into what you are testing.
    I would not want to drink any of the wine he is “monitoring”….
    Plus why monitor PH? it’s a useless measurement in winemaking as you will get stratification layers in the cask so to get an accurate measurement you need to mix the batch draw a sample and test. 99.9978% of all winemakers do not monitor PH.
    Let me monitor specific gravity…. Now you have something that is useful.
  • layne says:
    why not just use infrared emitter/sensor?
  • osgeld says:
    “Guys, I’m not sure what water systems have to do with this, this is not a pipe with something going through the inside.”
    you forgot soaking in a mild acid for months on end
  • rallen71366 says:
    @UltimateJim Actually, according to the Jack Daniels Distillery guide I had, an iron nail hammered into a cask will render it undrinkable. That’s why JD is so proud of their water supply: they pipe it from 2 miles underground and it’s iron-free. “Stainless” is more “Stain Resistant”, and doesn’t give up it’s iron easily to corrosion, or chemical recombination.
  • andy says:
    @fartface: Since the specific grav is changing due to the production of co2 and alcohol, you should be able to reverse engineer the gravity from a measurement of co2 / alcohol content. I don’t remember exactly but its (OG – FG)/something = %ABV. Seems like you sub in OG and %ABV and solve for FG and monitor that throughout. Although it obviously wouldn’t be final, it would be instantaneous, but at the end of the fermentation process that instant it would be final right… lol
  • Leave a Reply
    XHTML: You can use these tags: <a href="" title="" rel=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <pre> <del datetime=""> <em> <i> <q cite=""> <strike> <strong>
    Hack a Day serves up fresh hacks each day, every day from around the web as well as hacking related news.
    Send us your hacks
    Hacks
    Resources
