Vector Plotter With Lasers
[Hubert] sent in his experiments using HDDs, CDROMs, speakers, and other components to make an XY laser plotter. Those carefully reading will note, its not all three to make one plotter, but rather three plotters each using a separate system. The setups have their advantages and disadvantages, and [Hubert] is sure to point them out; including circuit diagrams and pictures to help you on your own trials.
There is a little difficulty in reading English not so good, but considering we’ve never seen a single-laser vector plotter done before (spirographs come close, and no one wants to wait 85 seconds) it’s still very impressive.
[Thanks TJ]
13 thoughts on “Vector Plotter With Lasers
  1. @TJ: Wow, I completely misinterpreted your email, thank you for notifying us. (Gave me a chance to fix some spelling errors too – I guess me/our editor’s brains are on vacation today.)
  2. I’ve found that the parallel ports on most PC’s (when you can find a PC with one) tend to be rather slow. Especially if you are using something like interpreted BASIC to drive the port. The best I could do with BASIC (many years ago) was something like 500 updates / second. Using C and the standard libraries may also impose a speed limit.
    Even so, you noticed that the hardware response was greatly affected by the signal frequency – this suggests that some sort of pre-emphasis 9equalization) may be helpfull.
  3. yeah sound card is the way to go i think. there is even softare for generating waveforms from vector images.
    i have tried this with a couple of hdd arms which sorta works. I think the high pass capacitors on the sound card need to be removed for good results
  4. @Brett
    using basic was your problem, PP logics analyzers easily hit 1 megasamples on pentium class hardware, when using a parallel laplink cable my 386 laptop can sustain 7mbit a second transfer (1 way)
    soundcards on the other hand the best your going to hope for is 44-96khz
Leave a Reply to fluidicCancel reply
