Tablet rig takes sheet music digital
music-stand-tablet-holder
[Bill Dudley's] wife wanted to use a couple of different tablets for displaying sheet music. Sure, a proper music stand will have no trouble supporting the weight of the device, but if it’s not secured it place you may soon have a broken device. [Bill's] solution was to build this tablet stand out of PVC.
The image above doesn’t tell the entire story of how he did this. But if you look really closely you’ll notice that the pipe is actually acting as a frame rather than a cradle. After measuring, cutting, and gluing all of the components together he cut a channel around the inside of the u-shaped PVC frame. The channel is the exact thickness of the tablet and holds the device securely. A base from a music stand makes up the rest of the rig.
Pages can be turned using a USB foot pedal. This is fantastic for gigging musician who use digital music collections like the Real Book.
Comments
  1. Squirrel says:
    I’ve always thought it would be cool to have an app that would listen to what you play and automatically turn the pages at the right time.
  2. Dave says:
    This man needs a router and a few scraps of oak
  3. Hack Man says:
    Appropriate use for PVC.
  4. tehnoo says:
    In all honesty, I probably would have just put a rubber band around the tablet/conventional music stand. Or a binder clip.
  5. Brassomat says:
    Since when the first e-reader devices hit the market, i wanted one for displaying sheet music (I’m playing trumpet). But for beeing really useful, such devices need a bigger display. It needs to be at least the size of a A4-page (297x210mm), better two pages/displays and to be foldable like a book. Devices like normal eReader (eInk-display) or Tablets are just two small to be read from a little distance, like with a trumpet in front of your head.
    I hope there will be a eReader/Tablet in such a format, because I’m already digitizing a lot of sheet music and books (brass literature). Having some books like the “Real Book” on a reader would spare me several kilograms!
  6. Praetorian_TMOTC says:
    I like Brassomat above also would like an e-ink solution for gigs etc. Anyone aware of a way to connect two e-ink devices in a master/slave display type arrangement?
  7. satovey says:
    Not a bad utility. However, when playing the piano, why not just rest the tablet on the lip that holds the sheet music?
    If you need the tablet closer for easier reading, just mount the holder to the backboard with Velcro or some other sort of easily removable mount like clamps?
    ST
  8. Sp`ange says:
    Harry Connick Jr. has been doing this for years with Macs. While touring, he has his band bring him their removable HDs at night and makes any changes. But that was several years ago. Not sure what he is doing now. It even had the added value of his band being bathed in blue light from the monitors. He even got a patent for the system.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 91,398 other followers
