Making QR Codes In Google Docs
screen-shot-2013-09-18-at-1-48-20-am
[Jordi] sent us this great tip on how to generate QR codes inside Google Docs. This can be super handy if you ever need to make a lot of them at one time, plus they update on the fly!
In his example he set up the code to create vCards so he could transfer contacts to his phone quickly and easily. The code pulls in a Google API QR generator and provides you with a QR code as an image! The following is his code, which can be easily modified to suit your needs:
=image("https://chart.googleapis.com/chart?chs=200x200&cht=qr&chl=BEGIN:VCARD%0AN:" & A2 & "%20" & B2 & "%0ATEL;CELL:" & C2 & "%0AEMAIL:" & D2 & "%0AEND:VCARD")
Or if you just want the bare bones:
=image("https://chart.googleapis.com/chart?chs=200x200&cht=qr&chl=<strong>YOUR CELL</strong>")
And if you need a full walkthrough, there is a video after the break. Those wanting to tinker around with more QR code hijinks will enjoy forming images from QR codes and milling QR codes into your copper layers.
[Thanks Jordi!]
6 thoughts on “Making QR Codes In Google Docs
  1. How would you add a field to this? For ex: If I created a column for job title, how would I include that in the formula? I have tried following the syntax from the other fields, but it is not working…
Leave a Reply to arturCancel reply
