Password-Free Guest WiFi From Raspberry Pi
Anytime you’re having more than a handful of people over to your place for a wild rager or LAN party (or both), you’ll generally need a way to make sure everyone can get their devices on the network. Normally, this would involve either putting your WiFi password into more phones than you can count or yelling your password across a crowded room. Neither of these options suited [NicoHood] and his partner, however, so he came up with another more secure solution to the WiFi-in-a-crowded-room problem.
He calls his project “guestwlan” and it’s set up to run on a Raspberry Pi with a touch screen. When a potential WiFi user approaches the Pi and requests access to the network, the Pi displays a QR code. Within that code is all of the information that the prospective device needs to connect to the network. For those who have already spotted the new security vulnerability that this creates, [NicoHood] has his guest WiFi on a separate local network just to make sure that even if someone nefarious can access the Internet, it would be more difficult for them to do anything damaging to his local network. As it stands, though, it’s a lot more secure than some other WiFi networks we’ve seen.
[NicoHood] also released his software on Git but it has been configured for use with Arch. He says that it would probably work in a Debian environment (which the Raspberry Pi-specific OS is based on) but this is currently untested. Feel free to give it a try and let us know how it goes.
31 thoughts on “Password-Free Guest WiFi From Raspberry Pi
  1. While on the topic of network security, my local pinstripes uses their public wifi network for all of their printers, point of sales terminals, computers, etc. It was fun poking around it :)
    1. This!
      This solution is pointless for conference situations where everybody bring their business-laptops with no QR-Code reading software on it. We also have a sheet with a Wifi-Guest QR-Code hangig in the conference room. Almost nobody is using it, because the top most use-case is laptop, not smartphone.
    2. You grab your cellphone, take a photo, turn on data, upload to cloud, turn on cellphone AP, connect laptop to said cloud, download image, throw it into an online qr code reader, copy paste the result and its done.
      You wont even need an USB cable!
      1. I have no problem with an USB cable, but I would not want to have to use cloud. Of course it is no problem:
        Scan and decode with cellphone, store as text. Copy to Laptop via Bluetooth or WiFi direct and copy/paste result to network login.
      1. Then you can still use an easy 4-6 character PW. Or does the contract specify a required password complexity? If yes, it still can’t be very high. My ISP uses 8 character (upper case and numbers) PWs printed on the bottom of the router/modem.
      1. I have considered this but decided against it for several reasons.
        Such a password is trivial to crack and offers a false sense of security for users who aren’t educated about this stuff.
        Open wifi (sometimes with captive portals, another false sense of security) is a widely accepted risk by the public.
        I don’t mind if the neighbors and passer-by’s use the connection, but I don’t want to be on the hook for technical support should there be any problems. Sharing the password requires revealing who I am to every user, and sharing it in a public manner defeats the encryption as well.
        I block services (such as FTP and SMTP) that are likely to leak passwords. Additionally I’ve found that these days, an amazing majority of the traffic is HTTPS. Normally all I see are HTTPS connections to Facebook, Google, and Netflix.
        Finally, wifi is inherently based on trust. Until there is a solution to the pineapple attack, every time you use wifi you are trusting every device in radio range. Obviously it’s still a good idea to use a password for your personal network but the marginal benefit is not very big.
    1. Except for the core concept of it. What if the attacker leaves a device in range of the network that acts like it gets its button pushed every 2 minutes so it is constantly waiting for the router’s button to be pressed? Then it’s purely by chance which device will be accepted into the network. Sure, if the legitimate device gets left out, the owner may notice it, but the default reaction is still “stupid thing didn’t work the first time, I’ll just keep spamming the button until it works”.
    1. The idea sounds nice, but is really bad in sense of security. If you know the wordlist that is used (or just try your own) the number of possible passwords is very low. The password can be hacked very fast. Even if you switch it every day. You can a) decrypt the traffic afterwards and b) you might be able to hack into the wifi fast enough if the wordlist is really small.
      A comparison:
      It takes 3 hours on my i7 laptop to crack an 8 digit password: 10^8 = 100000000
      Now if you have a wordlist with 10k entries it would take the same time: 10000^2 = 100000000
      You definitely do not want to use this approach. And that is also the reason why “word passwords” are not a good idea in any case.
  2. Just use you pi to connect to a vpn privacy service and share that link out wide-open, separate from any other network you have. That way it makes it easy for visitors to connect and you don’t have to worry about your IP being associated with “questionable” internet traffic. You can cap bandwidth or just turn the thing off when you don’t have company. Its best to keep it as simple as possible for guests.
Leave a Reply to mordacthedenierCancel reply
