a couple of you dell totin’ pocket pc hackers sent this in–turns out there’s a secret contrast app the you can unlock by editing the registry.
‘HKEY_LOCAL_MACHINEControlPanelContrast’ renaming the “redirect” value to “redirect_” (or rename to something else, or remove it completely). soft reset and go to start > settings > system > contrast and adjust the contrast.
Continue reading “Enable Dell X50 Series Pocket Pc Secret Software”
