apparently, greg miller is a class ‘a’ dumpster diver and high voltage hacker. aside from the image intensifier tube found on ebay, this night vision scope is made almost entirely from other people’s junk. something like this would add the perfect touch for creeping out friends with your silence of the lambs impersonations.
Wow..this is utterly amazing!
Most regular CCD AND CMOS imagers will see into the IR spectrum. (Some quite well.)
You could probably get the same effect with a standard black and white video camera and a larger IR LED array. (Although you wouldn’t get the convenient viewfinder!)
Great project!
i think you can do the same with a digital camera. Give this a try take your tv remote or any other ir remote aim it at your camera’s lens and look at the cams screen, you’ll see the infrared light. if you could build ir light with a bunch or ir leds you could use any old digicam with ir to make your gogles
Greg is a great guy with a ton of ingenuity. He is an inspiration for all high-voltage enthusiasts, and is the only person i know to have constructed a working Tesla coil out of nothing but junk. He is a Class-A hacker!
I seen this in popular electronics about 15yrs ago and called allover the country looking for them.(before ebay) but I rember reading that you can develop unexposed film, in big sheets to use
as an IR filter. for like a Q-beam :-)
DAN:
do you have anymore info on this??!
ya, i think it was in ~87 popular electronics
i just grabbed my sony handycam to see if this
works with the old negatives i have and just found out the kids used it in the bathtub !
or somthing. but the first google talks about
using trash bags too. wish I could try it out tonight but got to fix the cam now :-*
http://groups-beta.google.com/groups?as_q=film%20ir%20filter%20unexposed&safe=off&lr=&num=100&hl=en
this need more info, i want to do this!!!
would this work?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4084&item=6148632481&rd=1
Al-Queda thanks you
you’re welcome :-p
does anyone know where to buy fairly high intensity IR LEDs? I’m curious now about wiring something up for my digital camera to use…
Ya know, if you put too much high voltage into this thing, it stands a pretty good chance of emitting soft x-rays into your head…and that ain’t good…
Especially when X-Rays were FINALLY added to the known Cancer Agents list….
allelectronics.com sells cheap ccd cams. also you can use any ccd web cam for a project like this. by using either film, or a red and a blue filter place on top of each other, you can make a really good ir filter. that kind of filter works good on a flash light to make ir floods. I use a portable DVD player for my viewer.
How do you do that?
