Vacuum Forming
vacuum forming
Vacuum forming involves heating up a sheet of plastic and stretching it over a mold known as a “buck”. A vacuum is applied to pull the plastic up to the mold surface. The major parts are a table top grill and a shop vac. The author uses this set up to create studio props, but it can be used for a lot of other things. The acrylic bodies on RC cars are manufactured using this process. So, if you want to start generating your own custom bodies, this is where to start.
Continue reading “Vacuum Forming” →
TUAW Trys Out OSX86
Our friends over at The Unofficial Apple Weblog decided reinforce their name by trying out the OSX86. After some bumbling they got it installed (I don’t think they’re going to be Linux converts anytime soon). Conclusion? They were thoroughly impressed that it worked and how incredibly slow it was, deciding that it needed some more tweaking. I’m just happy someone else did this before I had to bite the bullet and sacrifice my only running laptop in the name of hacking.
Continue reading “TUAW Trys Out OSX86” →
