Underwater CVS Camcorder
cvs underwater
[Everett] got such a great response to yesterday’s nightvision hack he decided to write up this underwater CVS mod. The outside is a Pelican #1010 case. The camera fits almost perfectly inside. A small foam shim is used to position the camera lens between the two thick plastic ridges. Everett relocated the power button to the front of the camera and placed a guard around the shutter button on the back. The shutter is now wired to a reed switch at the back of the case. To start the camera recording he’s attached a magnet to a spring on the outside of the case that you slide over the reed switch to trigger it. If you missed it yesterday, he added an example shot from the nightvision cam. It isn’t swimming season so the only underwater pics he has are from the bathtub, which he luckily hasn’t posted. If you want to start hacking on a CVS cam, [morcheeba] warns that they still haven’t completely broken firmware 3.62 and above. Here is the FAQ.
Continue reading “Underwater CVS Camcorder” →
