Solar MintyBoost
We first wrote about the MintyBoost back in 2006. Today, Adafruit has created a tutorial for making a solar powered MintyBoost. Using a MintyBoost, a solar panel, LiPo battery and a charger, they built on their Solar LiPoly tutorial. They fed the power tap output of the LiPoly charger into the battery input of the MintyBoost to perform the voltage step-up for USB devices. Based on an instructable that used SparkFun parts, this tutorial shows how to use parts that are available from one source. We hear that there will be some evolution of the MintyBoost coming down the line that will including charging capabilities.
9 thoughts on “Solar MintyBoost
  1. hm. apparently, at least for me, you don’t need to be signed in to instructables to view all steps on one page anymore
  2. Any recommendations for an alternative to the charger circuit? (through hole IC I can ebay?)
    I want to use a lipo cell but at $15 its a bit expensive for the little project I want to use it for. However I do like how it has lines for output, charge, and battery so it can be integrated into the device.
