Recently, research students at Georgia Tech released a report outlining the dangers that GPUs pose to the current state of password security. There are a number of ways to crack a password, all with their different pros and cons, but when it comes down to it, the limiting factor in all of these methods is processing complexity. The more operations that need to be run, the longer it takes, and the less useful each tool is for cracking passwords. In the past, most recommendations for password security revolved around making sure your password wasn’t something predictable, such as “password” or your birthday. With today’s (and tomorrows) GPUs, this may no longer be enough.
Although the article never mentions them by name, the newest tools in password cracking are based around two tools, nVidia’s CUDA and AMD’s Stream SDKs. These tools allow programs to be written in C that can be broken up and utilize the parallel nature of the hardware that is usually optimized for graphics. GPUs are much better at large-scale mathematical operations than CPUs because of this parallel layout. Chances are, if you have a somewhat recent graphics card, it is probably compatible with either CUDA or Stream, and if you already know C, you have all the tools necessary to get started.
The lesson to learn here, the longer or more complex a password is, generally the safer it is. Because of this, a number of tools, both software and hardware, may become more and more popular, or necessary, to accommodate this need.
Thank you for informing me on password security with the use of GPU’s. I usually have unpredictable passwords, but they’re always short so I should make them longer to keep my accounts safe from hacking. Thanks for the tips about GPU’s!
Try using gpt-3 to code a driver to brute force sli settings on cyberpunk 2077 on that gpu in a mod driver here as nvidia and amd and intel will see it works on YouTube videos if successful here as cpu makes moving to ARM64 and ARM86 will look at this for easy coding on the cheap once proven for driver coding and fixes.
