You’re Stealing It Wrong: A Speech By Jason Scott
slipped disk in all of his glory
[Jason Scott], data historian extraordinaire gave this fantastic speech at Defcon 18 about the history of inter-pirate piracy. At an hour long, it is an enthralling journey through computer history, especially pertaining to piracy. Take a seat, no matter how much you know about security and piracy, you are likely to learn a few things. We find the lesser discussed issues like pirates stealing other pirates work interesting, as well as the part where pirates have to crack really boring software to have a release when there’s nothing better out there. Also worth noting, according to [Jason], the demoscene evolved from the little opening sequences from cracks. There are just too many interesting aspects to note here, even some porn related stories during the BBS days.
This is a great lesson from someone who is both knowledgeable and entertaining. [Jason] teaches this stuff without ever sounding stuffy, boring, or overly technical. Catch the video after the break.
Continue reading “You’re Stealing It Wrong: A Speech By Jason Scott”
GameBoy Advance Rapid Fire Hack
Ever find yourself in the middle of a Game Boy game and your hand cramps up?  Save that sore wrist for something else because now you can hack the Game Boy Advance to add Rapid Fire for the B button.  [William] has developed a way to do this by creating a simple circuit that generates a square wave on the B button when it is pressed.  To do this hack all that was needed was a short shopping list of:
  • A Couple NAND Gate ICs
  • 2n2222 NPN Transistor
  • 0.1uF ceramic capacitor
  • A Switch
  • 1M ohm resistor
  • Some Thin Wire
After that you’re off to the races as [William] documents how he goes about transforming the Game Boy Advance and includes a ton of great pictures and a schematic.  This operation ends with [William] placing the switch for Rapid Fire excellence next to the Right Bumper where it is inconspicuous and yet easy enough to access.
Via [HackedGadgets]
Mac Tablet Keeps The Look Of The Donor-Macbook
[Enigma-penguin] built a tablet computer out of a Core2Duo Macbook circa 2007. The battery exploded, damaging the case and a few components inside. But there was hope for a new life as a tablet computer. He removed the screen and tested to make sure the computer would still function without it by using the video out port.
Putting the whole thing back together as a tablet proved to have some headaches. He worked through problems caused by the addition of a touchscreen between the LCD and the bezel and made the connections work with the screen flipped. The finished product looks so good because the bezel has not been turned around like on other tablet builds. Instead, a viewing window was cut in what would have been the case behind the screen.
There’s a little more to be done yet. The black USB cable seen above is the connector for the touchscreen which he plans to internalize. The magnetic sleep sensor has been relocated to the headphone jack. Inserting a plug (no cord necessary) puts it to sleep for transport. There’s also an on screen keyboard and the ability to change the screen orientation from landscape to portrait. After the break we’ve embedded one of [Enigma-penguin’s] demonstrations. Continue reading “Mac Tablet Keeps The Look Of The Donor-Macbook”
