This is just an 8×8 LED matrix, but the size and execution make it look marvelous. [Michu] built this module using foam board dividers to separate the cells, a foam board back to host the 64 RGB LEDs, and a sheet of heavy frost diffusion gel that is a stage lighting product. The display is driven by a Rainbowduino with input from a processing sketch. The effects seen in the video after the break are quite pleasing, and are just begging to be installed in your next coffee table project.
[vimeo=http://vimeo.com/17715232 w=470]
Source code? Schematics?
So what makes the “Daft Punk”? Has Daft Punk become and adjective?
@macona Daft Punk became an adjective right after “and” became an indefinite article. :)
@macona
Daft Punk has always been an adjective. It’s a sub-genre of Punk, just because somebody uses it for the name of their music..doesn’t make it any less of a description or genre. So yes, it actually is.
@macona – It’s the kinda visuals you would see at a Daft Punk show.
It’s called a daft punk table because it’s a copy/form of this: http://www.youtube.com/watch?v=xfkQjGu3cBI which the creater called a daft punk table years ago.
This project seems kinda lame though because all it is doing is displaying low-bit “images” in a timed interval rather then cool visuals to the beat of the music.
What is the music in this video?
source code can be found here:
http://code.google.com/p/neorainbowduino/
and I dont know why my table is called “Daft Punk Module…”
Do you sleeping with a golden helmet?
toodlestech : It’s called a “Daft Punk Coffee Table” because the original model was designed by Daft Punk in 2004 for the british furniture store Habitat.
http://www.guardian.co.uk/lifeandstyle/2004/jul/09/homes
I don’t have the kind of money they charge for a “Golden Helmet”.
This ain’t Vegas.
Okay I might have misunderstood that…
just for your information, the next version of this huge pixel matrix is available at http://pixelinvaders.ch
cheers
