Hacking Strippers To Do Your Bidding
wire_strippers
[Alex] knows his strippers.
By his estimation, he has stripped millions of wires over the years, and he has seen his fair share of wire strippers come and go. That cheap set of wire strippers you have with the graduated holes, or that adjustable stripper you squeeze as you pull the wire through? They just stress the insulation as well as the wires you are trying to strip – he says you might as well just use them in your tackle box.
His favorite style of wire stripper is the automatic kind that grip the wire, then cut and remove the insulation just by squeezing the handles. His issue with this particular tool is that it’s difficult to get a uniform length of stripped wire when working in volume.
Since [Alex] needs uniformity in his line of work, he modified a set of automatic wire strippers to include an adjustable wire stop. He determines the length of wire he needs, adds or removes some washers from his wire stop, and off he goes. It’s a very simple yet very useful hack, depending on your application. We bet it is probably one of the most accurate ways to get uniform length, this side of a fully automatic wire stripper.
38 thoughts on “Hacking Strippers To Do Your Bidding
  1. Pretty sure I am not the only one thinking this article was gonna go a different route. Had a stack of $1 bills all ready too!
  2. I have the same pair as bob and they have served me extremely well, however they are not good for short lengths of wire as they pull the wire through the insulation sometimes…
  3. try looking at facom wire strippers they cut the cable aswell as stripping both ends of where you cut adjustable to twithin 0.5mm would never be without my pair whilst panel building
  4. Pretty nifty hack, but most come with an adjustable plastic stop. However, I do not use them. After enough repetition you develop an eye for it.
  5. First: A good Wire-Stripper is quite expensive.
    Second: Most automatic strippers dammage the insulation a bit, where they grip the wire. There are industries, where only non-damaging wire strippers are allowed. These look much like the one in the pictures.
  6. Speaking of strippers, did anybody else know that many stripper poles have bearings in them to enable angular rotation? I wonder what would happen if you installed thrust bearing instead?
  7. As we all know, angular rotation perpendicular to a shaft is best facilitated by a low friction surface. Preferably one with ball bearings.
    This video shows off the rotating effect quite nicely. She isn’t actually rotating herself (she can’t overcome that much friction anyway). The pole is rotating.
    http://www.youtube.com/watch?v=bbB2hiqn3sA
  8. “That cheap set of wire strippers you have with the graduated holes, or that adjustable stripper you squeeze as you pull the wire through? They just stress the insulation as well as the wires you are trying to strip – he says you might as well just use them in your tackle box.”
    Gotta nit-pick a little bit about this. Automatic wire strippers are nice and all but I wouldn’t throw the cheapies in the tackle box. I can’t be the only one who occasionally solders one end of a short jumper to a piece of proto-board then realizes that I forgot to strip the other end. Bulky auto-strippers won’t save you there.
  9. Methyl (1R,2R,3S,5S)-3- (benzoyloxy)-8-methyl-8-azabicyclo[3.2.1] octane-2-carboxylate doesn’t work as well as methane trichloride, one would think.
  10. “First: A good Wire-Stripper is quite expensive.
    Second: Most automatic strippers dammage the insulation a bit, where they grip the wire. There are industries, where only non-damaging wire strippers are allowed.”
    And these hold true to the regular strippers as well.
    Stay away from the automatic ones, they cause a LOT of damage.
  11. +1 for the automatic ones causing damage.
    At work we use a device that melts through the insulation. Not portable at all though…
  12. @ Fallen
    “At work we use a device that melts through the insulation.”
    How does that cope with PTFE insulation? And how do you cope with the fumes?
Leave a Reply to DaleyCancel reply
