RoboTouch Adds Physical Game Controls To The IPad
robotouch
[ProtoDojo] wanted to play a racing game on his iPad, but he was not a big fan of using the touch interface for this particular title. Instead, he put together a pretty neat little hack that allows him to play games on his iPad using an old NES controller.
He built a set of custom conductive arms which he mounted on three micro servos. The servos were attached to the iPad screen using small suction cups in the locations where it expects to receive button presses. They are also wired to an Arduino that interprets button presses from the attached NES controller. When the Arduino senses that the D-pad or buttons have been pressed, it triggers the servos, which in turn press the virtual buttons on the screen.
In the video below, you can see that after adjusting the servo positions, the setup seems to work pretty well. You might expect to see some sort of lag with a setup like this, but we didn’t notice any. The [ProtoDojo] web site is currently down due to heavy traffic, but you should be able to find some more build details there, once it becomes functional again.
11 thoughts on “RoboTouch Adds Physical Game Controls To The IPad
  1. Wouldn’t it be easier to keep the “arms” against the screen and use semiconductor switches to “activate” them? Is that impossible/difficult due to the capacitive nature of the screen? To what are the other ends of the arms (electrically) connected?
  2. HID, PC because Aliens and robots don’t want to be included with us. Don’t those i-things all have 3-way motion sensing? How about i-phone to i-pad control link.
    Give me a joy stick or wheel and pedals, or I might as well play on a watch (not much smaller than I-phone).
    Still a useful hack for many occasional button presses in certain apps.
  3. Would it not be possible to program a game for the ipod/iphone/ipad platform which uses the device’s headphone mic capability as an input device?
    These devices all use a microphone integrated into the headphones for sound recording so it should be possible to use the mic port as a communications port for a signal like a game controller input.
  4. Why not use some sort of solid state capacitance attachment that is activated when a button is pressed? If you want to not “plug” anything into the ipad, this seems like the easiest solution; other than your hands that is.
Leave a Reply to Christian Cancel reply
