Nixie Tube Conference Badge
troopers11_badge
Maker [Jeffrey Gough] was recently asked to construct a set of badges for the TROOPERS11 IT security conference held in Heidelberg last month. The badges were to reflect the overall theme of this year’s conference – personal progression, education, and striving to become better IT security professionals. To do this, he designed a badge that tracked a conference attendee’s participation in various activities.
The badge sports a center-mounted nixie tube that is used to show the attendee’s score. It is worn around the neck using a Cat-5 cable that acts as a LANyard as well serves as a power switch for the badge. The badge can be plugged in to a special programmer used by conference organizers, which updates the attendee’s score after completing each activity.
[Jeffrey] made sure to add all sorts of extra goodies to the badge, including a capacitive touch button that displays a secret message via the nixie, as well as plenty of hole and SMT pads so that hackers could get their game on.
Overall, the reception of the badge was extremely positive. All of the conference attendees had lots of fun exploiting the badges as well as adding components such as LEDs and speakers.
Continue reading to check out a quick demonstration video [Jeffrey] put together, highlighting the badge’s features.
13 thoughts on “Nixie Tube Conference Badge
  1. Nope, check out the design… he has clear heat shrink around the pins of the tube… and silicone encapsulant over the high voltage power supply parts.
    I guess you should be as worried as you would be about being burned while soldering. It’s possible, but not likely if you don’t stick your tongue on it.
Leave a Reply to Elliott Cancel reply
