A Capacitive Discharge Welder/cutter For All Your Lightweight Needs
microspot-welder
[Radu Motisan] wrote in to share a cool project he has been working on lately, a pulsed microspot welder/cutter.
The device is capable of spot welding thin metals such as foils and battery tabs by sending a pair of high current pulses between the two electrodes whenever [Radu] presses the trigger button. The cutting portion of his device uses the same general mechanism, though it requires a far greater number of pulses to get the work done.
The welding/cutting process is controlled by an ATMega16, which is also tasked with taking input from the user and displaying information on the LCD panel. The microcontroller creates quick (in the ten to several hundred microsecond range) pulses for both welding and cutting, with the latter obviously requiring a long series of pulses.
[Radu] started out using a relatively small capacitor array to power the device, but has recently upgraded to a 1.6 Farad car audio capacitor, which works (and looks) much better than before. His blog seems to update every few days with more pictures and details about his welding station, so be sure to check back often for updates.
Be sure to stick around to see a short video of [Radu] adding metal tabs to batteries and tearing down an aluminum can with his cutter.
[youtube=http://www.youtube.com/watch?v=BVj0Tey3SSM&feature=player_embedded&w=470]
20 thoughts on “A Capacitive Discharge Welder/cutter For All Your Lightweight Needs
  1. Looks like a lot of time spent with a pulse control, but not enough time spent on the deployment side…. All the arcing is good for pictures, but not good for battery tab welding.
  2. did you even watch the whole video? after the pictures he spot welds the tab in real time and you hardly see any sparks at all.
  3. Very nice build, will consider for a future workshop build. My question however, is why would anyone want to solder tabs to alkaline batteries? Rechargables would make much more sense in the long run.
    1. Hey Jake… Did you think that maybe he didn’t want to waste an rechargeable for the demo?
      And markS… Why would he use a new tab to demo it? So it’ll look pretty for you? He obviously had plans to attempt to rip it from the end of the battery (as he did at the end). In fact, I’m more impressed at the fact it worked on someone used (as often many of us attempt to make repairs and not complete replacement of parts)… If it was a joke, might want to add some indications of such in the future.
  4. IMHO the visible arcing when welding the tab was because the tab wasn’t flat. Normally I suppose you’d use a new bit of metal not an old scrunchy tab to demo it working. Of course nice visual sparks adds to the visual demo :-)
    Congratulations sir, on an excellent project.
  5. Could this sort of thing be used for thicker, beefier metals? I do chainmaille as a hobby, and have been interested in upgrading to welding the rings shut. I work with aluminum, stainless steel and titanium in various gauges.
    1. It might work for the aluminum rings if you flatten the ends of the rings first, make a hole in one of the flattened ends, and then weld it shut… But I can guarantee that it won’t work on the titanium or stainless steel.
    2. The only thing I can think of that would reliably weld aluminum, stainless steel and titanium is a TIG welder.
      http://en.wikipedia.org/wiki/Gas_tungsten_arc_welding
      I recently acquired one and it’s a very interesting process, sometimes it feels more like soldering then regular Stick or MIG welding. A good resource to familiarize yourself with the process is
      http://www.millerwelds.com/resources/TIGhandbook/
      If you don’t want to spend a lot on a machine from Miller or Lincoln I hear there’s some half way decent Chinese imports.
      http://www.weldingtipsandtricks.com/chinese-tig-welder-review-video.html
    3. Stainless and titanium might not be a problem but aluminum could be. It would most likely require even more current.
    4. Shielding gas flow control could be a problem, but not an insurmountable one.
      Have you tried a TIG welding setup yet?
  6. Whatever happened to the controller promised for hackaday’s own spot welder? It was a great simple high current power supply, but they never followed up on it.
Leave a Reply to YatesCancel reply
