Anyone who has played Minecraftfor a good amount of time should have a good grasp on making 3D objects by placing voxels block by block. A giant voxel art dragon behind your base is cool, but what about the math behind your block based artwork? [mikolalysenko] put together a tutorial for making 3D objects out of video game sprites and covers a lot of the math involved in turning pixels into voxels.
The process of modeling a 3D object from a series of 2D images is a very well-studied computer vision problem called multiview stereo reconstruction. This process has been used to build 3D models of random objects with devices such as the Stanford spherical gantry. Unfortunately the math for this algorithm is a mess, but there is another way: using photo hulls (PDF warning) to find the largest possible object from a series of images showing the top, bottom, left, right, front, and back views.
[mikolaly] put together an algorithm to produce 3D images from a series of images and even went so far as to build a web-based shape carving editor. With this web app, it’s possible to make 3D objects simply by inputting a bunch of colored pixels onto six 2D grids.
Once the models were complete, [mikolaly] sent some of the 3D models off to Shapeways for 3D printing. He’s completed Meat boy, Mario, and Link 3D sprites, all available for sale.
Now the only thing left to do is build a script to turn these objects into Minecraft object schematics.
(…and build out of Lego bricks.)
Do Joust!
Hi, I am the author of that blog. Here are some direct links to things people have made:
Meat boy: http://voxelsprite.0fps.net/?src=/uploads/50564b03243216d714000007.png
Mario: http://voxelsprite.0fps.net/?src=/uploads/50562d83243216d714000002.png
Link: http://voxelsprite.0fps.net/?src=/uploads/50562d60243216d714000001.png
Koopa Shell: http://voxelsprite.0fps.net/?src=/uploads/5059280a243216d714000069.png
Minecraft guy: http://voxelsprite.0fps.net/?src=/uploads/5059b75e243216d71400009c.png
Smiley thing?: http://voxelsprite.0fps.net/?src=/uploads/5059ae46243216d714000097.png
What exactly are those links supposed to show us? All I get is a white silhouette.
If you have WebGL, you should be able to see the objects and edit them. If you don’t have webgl, it uses three.js as a fall back, but sometimes it breaks and all you get is a white blob. The shapeways links should be more reliable.
now i wonder if anyone can turn the models in black and white 2 into plastic pieces so you can build the cities like life and monopoly
Here are direct links to the ShapeWays pages:
http://www.shapeways.com/model/703091?materialId=26
http://www.shapeways.com/model/702952?materialId=26
http://www.shapeways.com/model/702951?materialId=26
http://www.shapeways.com/model/705572?materialId=26
http://www.shapeways.com/model/706017?materialId=26
http://www.shapeways.com/model/705968?materialId=26
Could these models be printed on a 3D sugar printer, Mario looks like he’ed be pretty tasty.
Hi. How come http://voxelsprite.0fps.net doesn’t work any more?
