Hackaday sees a ton of projects featuring the WS2812 series of digitally controllable RGB LEDs, in the form of bare chips, RGB LED strips, or some form of Adafruit’s NeoPixels. All these WS2812 LED products have one thing in common – they’re chip LEDs, making some projects difficult to realize. Now there’s a new member of the WS2812 family – a through-hole LED version – that should be available through the usual sources sometime later this year.
The key difference between these and the usual WS2812 LEDs is the packaging; these are 8mm LEDs with pins for power, ground, data in, and data out. With the preexisting libraries, this 8mm LED should work just the same as any other WS2812 LED.
Aside from a through-hole package, these new LEDs are very diffuse and aren’t as blinding as the normal chip LEDs. If you want to pick up a few of these LEDs, they’re available here, 13 LEDs for $15. There’s a lot of potential here for RGB LED cubes, something we hope to see sooner rather than later.
well, thats prettty much what i’ve been looking for… 2 packs ordered :)
The solderingsunday site linked in the article says they’re WS2811. Does that change anything?
WS2812 is just a WS2811 (driver chip) with an integrated LED. A lot of times they saw WS2811 simply because that is original driver chip and the protocol you’ll need to communicate.
The ws2811 and ws2812 are slightly different in that the order of the colours in the three bytes are different IIRC. Probably the same chip but it was easier to wire the colours up differently when integrating the die with the led.
i now officially change my mind about the extremely strict (edit: fast)
communication needed for these WS’s
8mm diffuse? same chip-lumens? possibly built in capacitor? (or no need for one)
order me an unlimited supply!
Or $0.15 each on aliexpress (http://www.aliexpress.com/item/High-Bright-LED-8mm-4pin-full-color-RGB-LEDs-beads-light-for-WS2811-WS2801-LPD1886-1903/1567509647.html)
Scratch that. They’re just RGB LEDS :(
They are also available here: http://samuraicircuits.com/merch/index.php?id_product=44&controller=product
Here for a price of 26$ per 100pcs:
http://samuraicircuits.com/merch/index.php?id_product=56&controller=product
Initiated by https://www.mikrocontroller.net/topic/325107#new
Ok, have to correct myself, it’s 27$ per 50pcs.
LED cubes at $1+ per LED? Who would really spend so much money to build something so pointless. A 10x cubed would be well over $1k
10*10=100
Your math is a bit off or I’m missing something.
Nevermind I’m an idiot. Shouldn’t comment this late at night .
It’s a cube 10*10*10 is 1000, your maths is correct
Found them on eBay. 50 for $18:
http://www.ebay.ca/itm/50PCS-Bright-RGB-LED-8mm-Common-Anode-Diffused-for-WS2811-2801-led-string-light-/111132439464?pt=LH_DefaultDomain_0&hash=item19e00273a8&_uhb=1
*EDIT* again, missed the part about integrated WS2812B. It’s one of those weekends.
You guys, if you really post links, please make sure they are in fact WS28!
I would LOVE to get more links with actual WS28-type Products besides Strips in various density and the bare package.
For Example:
These are Breadboard-Friendly WS28 as well, if you solder a 90° 3pin head under them. I use them a lot when building prototypes and need only 2-4 as a user interface.
http://www.ebay.de/itm/261306933763?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
What I’m still looking for are rings. There are neoPixel-Rings in 2 or 3 sizes but nothing interesting for me (diameter between 200-300mm/8-12inch).
How about this?
http://forum.43oh.com/topic/4920-120-led-ring-clock/
Search on youtube gives scores of videos of people that made RGB LED cubes
https://www.youtube.com/results?search_query=RGB%20LED%20cube
I am sure the price will come down in time.
In the mean time one of these:
http://www.aliexpress.com/item/100-NEW-ORIGINAL-200PCS-WS2811-LED-Drive-IC-Chip-256-gray-level-use-for-led-strip/1578148390.html
With one of these:
Make a compatible package.
Cool!! I made myself a breakout board for the SMD square WS2812B. Figured others might want some so they’re on Tindie.com. You can find some other WS2812B goodies on there from other vendors. Not sure if anyone is carrying the thru-hole version though.
