If you are looking for a way to spice up your summertime parties, try following [Pastryboy’s] lead. After letting the idea rattle around in his head for a few years, he finally built himself the cooler he always dreamed of.
[Pastryboy] was originally inspired by a YouTube video he found a few years ago. He took the basic concept and rolled with it. He started out with a mini fridge he found for $10. He removed the compressor and other plumbing bits. He also removed all of the internal shelving. Any leftover holes were patched up with silicone. Now when the fridge is laid on its back, it’s essentially the same as an ordinary cooler.
Next [Pastryboy] purchased two 6.5″ Boss speakers and an inexpensive head unit. He drilled a few pilot holes in the side of the refrigerator and then used a jigsaw to cut the holes to the proper sizes. Once the speakers were mounted in place, he needed to find a way to waterproof the inside. This was accomplished by using some small plastic bowls. The edges of the bowls were attached to the cooler wall using silicone.
[Pastryboy] was able to run most of the cabling through the inside of the cooler’s walls. The system is powered by a 12V lead acid battery. He chose a specific model of battery that can be stored in any orientation and that can handle being knocked around a little bit.
Next he added a couple of handles to the sides to make it easier to transport. A small bit of ski rope was attached to the inside of the lid, preventing the lid from flopping completely open. [Pastryboy] also added a drain to the bottom to make it easier for one person to empty the cooler. The final touch was to pretty it up a bit. He sanded down the entire thing and gave it several coats of red paint. The end result looks very slick.
[via Reddit]
Cool.
It’s missing a bottle opener bolted to it.
Horses for courses. A cooler is for keeping things cold, A boom box is for making noise. Plus coolers are often pressed into service performing tasks that are not exactly electronics friendly. Being durable, and simple insulated boxes coolers can handle the abuse. This added nonsense takes away from that fact. Just because you can does not mean that you should. I say let a cooler just be cool. Adding a stereo to a cooler makes it no cooler in my eyes.
It needs wheels!
Wheels like this?
http://www.ridingcoolers.com/main%20art/ban_index/banner07_resize.JPG
Not bad at all. Cold beer and music is the perfect combination
