Hackaday Tours Northrop: Space Telescopes And Jet Planes
I was invited to tour the Northrop Grumman Aerospace Systems campus in Los Angeles this spring and it was fantastic! The Northrop Grumman lists themselves as “a leading global security company” but the project that stole my heart is their work on the James Webb Space Telescope (JWST) for NASA. On the one hand, I don’t see how it could possibly be pulled off as the telescope seems to cram every hard engineering challenge you can think of into one project. On the other hand, Northrop (plus NASA and all of their subcontractors) has been doing tough stuff for a very long time.
How Do You Tour Northrop Grumman?
This opportunity fell in my lap since [Tony Long] is a Hackaday reader and an engineer at Northrop. He’s the founder of their FabLab (which I’ll talk about a bit later) and was so bold as to send an email asking if one of the crew would like to stop by. Yes Please!
I was already headed out to the Supplyframe offices (Hackaday’s parent company) in Pasadena. [Tony] offered to pick me up at LAX and away we went to Redondo Beach, California for an afternoon adventure.
James Webb Space Telescope: Everything Hard About Engineering
I had heard of the James Webb Space Telescope (JWST) but had never looked closely at the particulars of the project. Above you can see a scale model which Northrop built. I didn’t actually see this on my tour. It travels to different places, taking two semi trucks, with a dozen people spending four days to set it up each time. And that’s a not-real, relegated to the surface of the planet, item. What is it going to take to put the real one into space?
It’s not just going into space. It’s going to the second Lagrangian point. This is past the moon, about 1.5 million kilometers from the earth. If this thing breaks we can’t go out there and fix it. There’s a lot of pressure for success.
The main problem facing this satellite is heat. It will use a mirror array to harvest infrared radiation from very distant astronomical bodies. For this to happen it needs to have a very good optical array to gather infrared light and focus it on a collector, and it must be isolated from the heat of the sun, earth, and moon.
There is an array of 18 hexagonal mirrors which reflect the infrared onto a collecting mirror and in turn to the sensors. These mirrors are not made by Northrop, but they did have a prototype on display and it was incredible! Each mirror is made by Ball Aerospace out of beryllium. The concave surface is coated in gold for reflectivity and an actuator mounted on the back of each mirror can flex the surface to adjust the concavity and thereby the focal length. This is in addition to the ability to adjust the roll and pitch of each segment.
In the Northrop high bay they were working on the mounting system for these mirrors. It showed much more progress than the two images seen above. This is the central mount structure for the optics. The width of this structure is dictated by the size of the rocket which will launch it into space. When I saw it, folding wings had been added to either side of this main structure to host a dual-row of mirrors which are folded back into the telescopes during its storage position. The black material itself is a composite manufactured by Northrop. The cross-section they showed as an example was not much thicker than your fingernail but obviously quite rigid in the cast pipe shape.
You can see an animation of the unfolding process which was playing in the high-bay viewing room during the tour. Note the five-layer heat shield that needs to automatically unfold without snagging. This reminds me of [Ed van Cise’s] recollection of solar panel unfolding issues on the ISS. It’s a tough problem and it looks like much time has been spend making sure this design learns from past issues. That animation doesn’t show too many details about the mirror mechanics. I found video demonstrating how the mechanical part of the mirrors work to be quite interesting.
Learning more about what goes into the James Webb Space Telescope project is worth a lot of your time. I’m not joking about this including everything hard about engineering. The challenges involved in meeting the specification of this telescope are jaw-dropping and I’m certain the people working on the project across many different companies will make this happen.
Hackerspace Driving Corporate Culture
fablab-wide-shot
It was nice that [Tony] and his colleague [Adam] came right out and told me they reached out to Hackaday because they want to get the message out that Northrop is rejuvenating their corporate culture. They’re in the process of hiring thousands of engineers and part of this process is making the job fit with the lifestyle that these engineers want.
One big move in this direction is the formation of their FabLab. [Tony] is an engineer but 50% of his workload is tending to the FabLab. This is basically a hackerspace open to any of the roughly 20k employees at this particular location. Northrop fabricates amazing things, and when equipment is no longer used, the FabLab gets dibs on it. Imagine the possibilities!
unexploded-armament-removalPart of this initiative is to get more engineers learning about the fabrication process. [Tony] used the example of researching by fabricating a simple proof-of-concept in the FabLab. This is an avenue to that buzzword: fail-fast. Before getting your department on board with what might be a costly and time-consuming project you can test out some of the parts which are a little hazy in your mind.
The device seen here is the product of a challenge that one of the groups participated in last year. They had about six months to develop a robot which can clear unexploded armaments. It was hanging out in one part of the hackerspace and is a great build. You can just make out a blue sphere hiding in the underbody. That’s a huge jamming gripper powered by the black and yellow shop-vac perched atop the chassis. The robot is remote controlled, with wireless GoPro cameras mounted all around and underneath. Of course the thing wouldn’t be complete without a giant silver air-horn. Safety first!
It will be interesting to see if the FabLab can build the kind of grass-roots community often associated with standalone hackerspaces. You can get a glimpse at the grand opening of the space in this video. We don’t quite remember seeing a hackerspace marketed in this manner. But if that’s what it takes to get the company on board it’s well worth it. A huge space, amazing tools, and no monthly membership fee make for a sweet deal. Oh, and the name FabLab apparently came from their mascot, the Fabulous Labrador, who can be seen in the clip wearing a string of pearls.
F/18 Assembly Plant
08001016_Small_File_
We wrapped up the day by touring the F/A 18 E/F Super Hornet assembly line. This is a huge plant. I don’t know how to better describe the sheer size of the assembly line than saying it took no less than twenty minutes to walk back to the parking lot at the end of this tour.
00036301Northrop Grumman serves as the principal subcontractor for Boeing on this project, so the end of the line isn’t quite a fully assembled airplane. But the fuselage — less cockpit, nose, wings, and engines — is still a formidable sight. I’ve never been this close to a fighter jet before and the size is impressive. Equally impressive is the building housing the line, which was build in 1942 and is still wood-framed to this day. They have huge engineered columns which have since been reinforced with steel. But that fact makes it no-less impressive.
The top concern during assembly is FOD, or Foreign Object Detection. These vehicles are exposed to huge forces and vibrations that will shake anything that’s not supposed to be there loose, and that can mean horrible damage to an expensive machine or much worse. Some of the things I found really interesting were the systems in place to make sure no part goes missing. All components come in cases that have an individual cutout area for each. Tools are scanned to each employee, if broken or worn out there are vending machines throughout the plant keeping track of them through a computerized system.
As part of the tour we walked through the composites plant next door. There are massive autoclaves for curing the resins. These are like a pipe sitting on its side with hemispherical doors on each end. I’m a poor judge of time and distance but I’d estimate these to be 18 feet in diameter and at least 35 feet long. Traditional composite fabrication — a worker laying down sheets of carbon-fiber on a mold — were under way. But the room next door housed a robot that looked like it was born in The Matrix. The spider-like head works next to a turning mandrel fitted with the form of the piece being fabricated. It lays out about seven strands of carbon fiber, building up a part that has no seams whatsoever. After curing the resin the mold is removed manually, piece by piece, from the inside of the part. To me the parts being built looked like air intake channels approximately 15 feet long and maybe 5 feet in diameter, although they were winding and not exactly cylindrical in shape. I wasn’t able to get very many details about them, but I was told these parts are for the F-35 Joint Strike Fighter. This is another subcontract Northrop Grumman has for Lockheed Martin.
Conclusion
Thank you to [Tony Long] and [Adam Gross] for spending to give Hackaday this tour. I had the impression that I was living an episode of one of my favorite programs How It’s Made, and that was awesome! Northrop Grumman has an educational outreach program so if you’re associated with a school in the area set up a tour of the JWST!
[Tony] ducked out with me for dinner; some excellent tacos — a quest I’ve been on during each visit to LA. He joined me afterward on a trip to Null Space Labs for their open night. They had moved since the last time I was there and if you’re in town you should check it out.
Attributes:
One thing I should mention is that I was not able to take any photographs on the premises. My story above is original but all the photos are stock or provided by Northrop at my request.
Main Post Image via JWST Flickr
Front Mirror via YouTube thumb.
Extended Reflection Mirror via YouTube video.
32 thoughts on “Hackaday Tours Northrop: Space Telescopes And Jet Planes
      1. Actually, it can be. Many commercial buildings are designed for a life-cycle of 50 years, at least the ones I worked on were. I find it impressive that a 70+ year old building is still useful, and will be for the foreseeable future.
          1. The MSR looks like the pyramid under the all-seeing eye, therefore it follows that the building being shut down after a weeks is what he Illuminati *wants* you to think. :p
    1. What didn’t come from the Germans came from spying on Russia and Asia.. Most US born prodigies go for leisure studies and consumerism or are socially driven to extremism because they embrace ideology..
        1. The chinese also got stuff from russia.
          And as for driving their ideology; I think they aren’t very pushy with that outside their realm, at least not compared to us in the west. We certainly know how to push.
          But it’s actually a bit of a question for me on their technology, we obviously hear about their stealing stuff over the years, but I don’t think we would likely hear about stuff they invented, not only because they would seek to keep it a secret if it’s military significant but also because it would not fit our western propaganda to mention it.
          I know they have some great mathematicians though who made some good advances in cryptography, and I know chinese that moved to the US are spearheading some technological inventions in US universities, showing they have the mind for it and showing there must be native chinese in china doing the same outside our knowledge.
  1. In the “How the mechanical parts of the mirror works” video does she really say “what makes this mirror different than one you may have in your bathroom”?
    I think the idea of a flexible, adjustable focal length and direction mirror fascinating. They were doing alignment on a “reddish” colored bed. Any ideas what that could be made of?
  2. That unexploded-armaments robot would look right at home at a FIRST competition. It’d be awesome if these guys are mentoring FIRST teams in their area.
    1. I find it an interesting post, a space telescope beyond the moon, a robot to clean abandoned minefields, those things help mankind, what a former President called “The Peace Dividend”.
      1. I think it’s very remiss to ignore the purpose of what they build (say, the F/18) and instead choosing to gush about how cool and impressive everything is and how great it is to have a hackerspace at work. It’s disingenuous and makes the article read like an advertising brochure for potential employees or tourists.
        Northrop Grumman is a company whose primary business is the making of killing machines which help maintain USA’s global hegemony.
    1. The IR one mentioned costs 8.8 billion I gather, so I guess we’ll have to wait for some big player to throw money at a visible light one.
      But seeing the previous one was also IR I’m not sure they want a visible light space telescope, unless it’s directed at our backyards of course, they launch new ones like that every month I bet. Maybe they can turn the old ones around and make some pictures of the universe with it.
      1. Yeah, the IR telescopes “see” through cosmic dust, so the astronomers can “see” more of what is happening out there, and that is their priority, but a visible light telescope would keep the taxpayers happy.
      2. There was a recent news story about a left over NRO sat sitting in storage that was being offered to NASA to replace Hubble (it was comparable to Hubble in performance). The problem was coming up with funding to retro-fit and launch it.
        1. I think some work is being done to those as of recently, but slowly. I’ll have to look them up. I recall it’s a bit of a thorny issue as the design is still classified, so they’re not allowed to show us what they look like.
    2. You can’t use visible light on distant galaxies, they’ve either red-shifted to much, or the light isn’t high enough energy to make it to earth. Nearly all pictures you see are IR, except maybe local solar system pictures from earth. Most satellites are IR as well. The color, and such you see in pictures are estimations, and colorizations, not real color.
  3. So, on a related note, did you guys see that pdf about the drone operations of the US? It’s sort of interesting from a technical viewpoint too.
    Of course the big story about it was that it showed all drone operations in yemen/afghanistan/somalia/pakistan/iraq/etcetera link via fiber from the US and such to rammstein airbase in germany and from there it’s unlinked to a satellite and then to the drones. Showing germany has a rather big complicity since they are the main hub.
  4. JWST is challenging, worked on the project, you have no clue the idiots who work on this program. Much of the company is controlled by managers who choose engineers worse than them. The place is full of people with nothing but a BS from Long Beach State or University of Hawaii. Incompetence, back-stabbing and nepotism run supreme. Want to know the real reasons why the program is years behind schedule, massively over-budget and will likely fail on orbit?
    This place was once top-notch, until the BS and BS with MBAs took over. Now this will be the slow end of space at this location.
Leave a Reply to Jeff FaustCancel reply
