Color-Changing LED Makes Techno Music
As much as we like addressable LEDs for their obedience, why do we always have to control everything? At least participants of the MusicMaker Hacklab, which was part of the Artefact Festival in February this year, have learned, that sometimes we should just sit down with our electronics and listen.
With the end of the Artefact Festival approaching, they still had this leftover color-changing LED from an otherwise scavenged toy reverb microphone. When powered by a 9 V battery, the LED would start a tiny light show, flashing, fading and mixing the very best out of its three primary colors. Acoustically, however, it spent most of its time in silent dignity.
singing_led_led_anatomy
As you may know, this kind of LED contains a tiny integrated circuit. This IC pulse-width-modulates the current through the light-emitting junctions in preprogrammed patterns, thus creating the colorful light effects.
To give the LED a voice, the participants added a 1 kΩ series resistor to the LED’s “anode”, which effectively translates variations in the current passing through the LED into measurable variations of voltage. This signal could then be fed into a small speaker or a mixing console. The LED expressed its gratitude for the life-changing modification by chanting its very own disco song.
singing_led_hook_up_schematic
This particular IC seems to operate at a switching frequency of about 1.1 kHz and the resulting square wave signal noticeably dominates the mix. However, not everything we hear there may be explained solely by the PWM. There are those rhythmic “thump” noises, shifts in pitch and amplitude of the sound and more to analyze and learn from. Not wanting to spoil your fun of making sense of the beeps and cracks (feel free to spoil as much as you want in the comments!), we just say enjoy the video and thanks to the people of the STUK Belgium for sharing their findings.
Retro Rotary Raspi Phone Rings Alexa
[MisterM] is a man after our own heart. He loves to combine the aesthetic of vintage equipment with the utility of new technologies. His latest venture is AlexaPhone, which marries the nearly instantaneous retrieval and computation power of Amazon’s Alexa voice service with the look and feel of a 1970s rotary phone. Best of all, there’s no need to spin the dial and wait for it to go whirring back around. AlexaPhone is ready to take questions as soon as the handset is lifted.
Questions are transmitted through a salvaged USB VOIP phone plugged into the Pi. The user must hang up the receiver in order to trigger the search. Once Alexa has an answer, the audio comes back through a small external amplified speaker with a USB-rechargeable battery. Since the hardware is a bit atypical for Alexa, [MisterM] had a bit of trouble at first trying to query the service with a physical button until he came across this AlexaPi code.
This phone is actually a reproduction of a classic BT Trimphone, which explains the asterisk and octothorpe on the dial.  The modern internals meant that [MisterM] could take advantage of the ribbon cable coming off of the receiver hook to trigger the Pi to send the query. Watch [MisterM]’s kids put Alexa through her paces after the break.
If this has you feeling nostalgic, check out this vintage Chromecast TV we covered recently or this old Russian radio reborn as a Bluetooth speaker.
Continue reading “Retro Rotary Raspi Phone Rings Alexa”
