DIY Vacuum Chamber Proves Thermodynamics Professor Isn’t Making It All Up
[Mr_GreenCoat] is studying engineering. His thermodynamics teacher agreed with the stance that engineering is best learned through experimentation, and tasked [Mr_GreenCoat]’s group with the construction of a vacuum chamber to prove that the boiling point of a liquid goes down with the pressure it is exposed to.
His group used black PVC pipe to construct their chamber. They used an air compressor to generate the vacuum. The lid is a sheet of lexan with a silicone disk. We’ve covered these sorts of designs before. Since a vacuum chamber is at max going to suffer 14.9 ish psi distributed load on the outside there’s no real worry of their design going too horribly wrong.
The interesting part of the build is the hardware and software built to boil the water and log the temperatures and pressures. Science isn’t done until something is written down after all. They have a power resistor and a temperature probe inside of the chamber. The temperature over time is logged using an Arduino and a bit of processing code.
In the end their experiment matched what they had been learning in class. The current laws of thermodynamics are still in effect — all is right in the universe — and these poor students can probably save some money and get along with an old edition of the textbook. Video after the break.
https://youtu.be/3EdHr8dYTbQ
34 thoughts on “DIY Vacuum Chamber Proves Thermodynamics Professor Isn’t Making It All Up
      1. PVC isn’t acceptable for this application. One problem is that PVC turns into shrapnel when it fails. Also, the oils typically used in air compressors (and vacuum pumps) cause degradation of the piping over time. PVC will fail a OSHA inspection when used for compressed air.
        Use something that stretches/crushes and remains mostly intact when it bursts, and doesn’t degrade from the oils used in the pump/compressor.
      2. Using the browser word search didn’t the words air or gas. The reference deal with fluids only. Many metal fitting have two pressure rating ratings on for fluid another for steam. The maximum pressure under steam is lower than for fluid. Of course PVC isn’t going to handle steam, but I have never seen any plastic pipe imprinted with maximum pressure rating for gas.
  1. “… to prove that the boiling point of a liquid goes down with the pressure it is exposed to.” Huh? I was taught in physics class too many decades ago that the boiling point (temperature) of a liquid goes UP with pressure (and down with a reduction in pressure). That is why water boils at room temperature in a partial vacuum (below the vapor pressure of water). Has somebody gone and changed the laws of physics since I attended University? Or is that a typographical error?
      1. The wording suggests an (untrue) inversely proportional relative pressure CHANGE. Accurate language is important when this forum attracts geeks (most of whom have some degree of Asperger’s Syndrome, where word precision and accurace is the major key to understanding). We are all at least a little like Sheldon Cooper (Big Bang Theory TV show) or we would not be here, right? Or better yet, think Spock (that does not compute!)… ;-)
    1. Or more simply, the original choice of words in the first post above suggests that the boiling point varies INVERSELY (goes down) with pressure, which is incorrect.
      https://en.wikipedia.org/wiki/Vapor_pressure
      “The atmospheric pressure boiling point of a liquid (also known as the normal boiling point) is the temperature at which the vapor pressure equals the ambient atmospheric pressure. With any incremental increase in that temperature, the vapor pressure becomes sufficient to overcome atmospheric pressure and lift the liquid to form vapor bubbles inside the bulk of the substance.”
  2. I do this demonstration in class, though I use a bell jar and borrow a student’s uncapped water bottle (be sure it’s single-wall so it doesn’t burst). When I give it back to them colder than before, the whole class “gets it” in a way that might have taken a whole lecture or two otherwise…kind of a turning point for the concept of enthalpy/vapor pressure etc.
    It doesn’t hurt that this is usually before the spring thaw so we have steam condensing in the baseboard air handlers to show how that enthalpy tied up in vapor can be used somewhere else.
    When I then link that to vacuum cooling of produce they understand why we can have fresh lettuce in the dead of winter.
    http://www.southernvacuumcooling.com/Vacuum%20Cooling.htm
Leave a Reply to TomCancel reply
