An Organ Made From Back-Driven Steppers
[Josh] wrote in to tell us about an experimental instrument he’s been working on for a couple of months. We’re glad he did, because it’s a really cool project. It’s an organ that uses the principle of back-drive—applying torque to the output shaft of a motor—to create sounds.  [Josh] is back-driving four octaves worth of stepper motors with spinning wooden disks, and this generates alternating current. At the right speeds, the resulting sinusoidal waveform falls within the range of human hearing and can be amplified for maximum musical enjoyment.
[Josh] built this organ from the ground up, including the keys which are made from oak and walnut. Each of the forty-nine stepper motors has a corresponding wooden disk. The larger the wooden disk in the stack, the higher the resulting pitch. [Josh] says that if he built it for a full 88 keys, the highest note’s disk would be sixteen feet in diameter.
This stack of disks is driven independently by a separate DC motor, and the speed determines the key it will play in. When [Josh] plays a note, that note’s lever is actuated and its stepper motor makes contact with its disk in the stack. When they meet, the motor is back-driven by the spinning disk. In other words, they work in concert to produce some cool, eerie sounds.
Here’s a somewhat similar sort of build made from lasers and fans, if you consider that both instruments create music from objects that weren’t built to do so. Watch [Josh] play his stepper organ after the break. He has several build videos on his YT channel, and we’ve also embedded the one that covers the motor, power, and electronics part of the build.
Continue reading “An Organ Made From Back-Driven Steppers” →
A Windowless Elevator With A 360º Panoramic View
The Amoreiras Tower, in Lisbon, Portugal, recently added a rooftop viewing area that is open to the public. The top of the tower is one of the highest spots in the city, and the viewing area gives an impressive 360º view of the surrounding area. However, the elevator to get to the top left a lot to be desired. It’s an interior elevator, and didn’t itself offer any view.
So, Artica, along with Schindler, were brought in to solve that problem. The solution was to mount displays on the interior of the elevator, in order to simulate a 360º panoramic view of the city outside. The video is synced up with the elevator, so the view changes as the elevator passengers move up and down between floors.
Artica, who was responsible for the concept, design, and electronics installation accomplished this by first building a prototype in their office building. This was a full-size elevator replica with which they could test the design and get it ready for installation. They then partnered with Schindler to actually install the system in the elevator of the Amoreiras Tower, which necessitated almost completely rebuilding the elevator. As you can see in the video, the resulting view and accompanying music (definitely not elevator music) are fantastic, and it was even done in time for the public opening of the rooftop viewing area.
Like us, you may be wondering where the video footage came from. The scene moves in apparent parallax so video was obviously captured with continuous motion and isn’t a scrolling image. This is the work of a camera toting drone.
Continue reading “A Windowless Elevator With A 360º Panoramic View” →
