If you ever want to pique a kid’s interest in technology, it is best to bring out something simple, yet cool. There was a time that showing a kid how a crystal radio could pull in a radio station from all the way across town fit the bill. Now, that’s a yawner as the kid probably carries a high-tech cell phone with a formidable radio already. Your latest FPGA project is probably too complicated to grasp, and your Arduino capacitance meter is–no offense–too boring to meet the cool factor criterion.
There’s an old school project usually called an “electromagnetic train” that works well (Ohio State has a good write up about it as a PDF file). You coil some bare copper wire around a tubular form to make a tunnel. Then a AAA battery with some magnets make the train. When you put the train in the tunnel, the magnetic forces propel the train through the tunnel. Well, either that or it shoots it out. If that happens, turn the train around and try again. There’s a few of these in Internet videos and you can see one of them (from [BeardedScienceGuy]) below.
This isn’t a new idea, but the Ohio State instructions are well suited for use in a classroom or just to work with an intellectually curious kid. Since this is simple enough, you can work with the kids (or kid) to actually build the device or let them build several in groups.
Getting kids interested in tech might be the ultimate hack. If you are looking for other ideas, you can try an electromagnetic egg drop (or a more traditional one) or a little pretend robot exercise.
Great hack
Hmmm, wonder how much power you need to send a bean can down a dryer hose….
I guess that depends on how you react to a can full of beans….
finally a use for those maxwell supercaps!
Our company used to make parts which utilized neodymium magnets. The magnets came in uncharged, we installed them and charged them. The magnets themselves were very small, about half inch by half inch, maybe 1/8 inch thick. We built a prototype charger, which simply consisted of stepping up the voltage, rectify, charge a large bank of capacitors and a very large SCR to dump the charge into a coil. This was NOT your daddy’s DC power supply. The parts we used rated in the hundreds of amps….
The first prototype charger we used a large piece of PVC pipe (probably 3 inch diameter) and wound copper tubing around. The copper tubing had a fiberglass sleeving installed on it as an insulator prior to winding, could have been anything, that was what we had at first. I still remember the look on the faces of people while we rigged up the lathe as a coil winder. We basically grabbed what we had and threw it all together because the beancounters wouldn’t allow a budget at the beginning but wanted to be making a product on some ungodly time scale!
We could easily put any metal slug in it, say a large bolt or nut, and shoot it across the lab.
After that we had to go outside, dragging frankencharger on wheels, to do further testing. We had to buy and build a special water cooling system to run water through the tubing because, duh, dumping several hundred amps into a copper coil numerous times made it hot.
Magnet charging isn’t special, but one has to make sure it is fully charged…..
By the end, we could shoot metal slugs over the two story roof and into the front parking lot, where many of the bean counters and managers parked.
Nothing intentional, just an added perk.
This prototype is still around, it worked as a few years ago, though we changed the charge coil for charging magnets. Much, much more concentrated magnetic field.
Another thing about strong magnetic fields, they can pass through walls. So, for all you computer geeks who seem to have that arrogant, I am God attitude, a well placed coil on the other side of the wall of a server room will cause hard drives to crash and erase data. It will also play hell with electronics, especially relay coils…..might want to think twice of who you talk down to next time youre assistance is required…..
Does charging magnets get any easier if you bring them near, but below curie point?
Very interesting and fun! Thanks for sharing.
“This isn’t a new idea”
I agree:
http://hackaday.com/2014/12/04/amazing-sciences-simple-electric-train/
I thought this was familiar…
My childhood was much more fun, with scale model trains and switch points and little people and little buildings.
As for kids today, my son liked 50kV plasma.
ME GUSTA! Something fun to do with almost-dead cells.
Won’t work—this needs lots of power. My go-to for dying batteries was (before I switched to Eneloops) cheap flashlights scattered around anywhere I thought I might need one. Sometimes a few minutes of dim light is all you need.
Though tip, cells in series dont deplete evenly. Swap them round and get the last bit out.
Haha yeah, I do that as well! There are some great ones that have white, red, and a ‘blood-tracker’ mode (blue and red).
https://www.walmart.com/ip/Generic-20144-Bushnell-TRKR-140L-Multi-Color-Flashlight/42441352
I own several versions and the next brightest model is my favorite.
All well and good until it gets stuck and the battery explodes (:
Only a problem with the Samsung model.
However, the load on the battery should be about the same whether or not the “train” is moving, should it not?
Unless it welds itself down, I’d assume you’d have an extra ohm in circuit from 2 points of shitty contact, gets stuck, it has the potential to weld in place lose some of that resistance, and thus more rapidly discharge the battery.
Trying to post a link to a site with wonderful info on this project, but it isn’t working (Al, do you hate me for some reason?). So, just search for “wayne schmidt this and that” and scroll down to find the “simplest train” link. Be sure to watch both videos!
Nope, the site is picky about links. Here you go: http://www.waynesthisandthat.com/How%20To%20Build%20The%20Simplest%20Electric%20Train.html
that is great!
“There was a time that showing a kid how a crystal radio could pull in a radio station from all the way across town fit the bill. Now, that’s a yawner as the kid probably carries a high-tech cell phone with a formidable radio already.”
Pocket sized transistor radios are a lot older than I am. I remember thinking the lack of a power source was impressive when I was a kid.
I’d like to see some snot nosed kid with a cellphone go without a charger!
I’d like to see a crystal radio give 80dB audio output!
No problem, I’ll just need a few dozen miles of solid copper wire and your assistance to festoon all the trees with a mile radius of a convenient AM transmitter with it….
Ben Franklin would probably have something discouraging to say about that idea. On the other hand, ET would adore it.
Given a choice between 80dB audio output and hearing ability, I think I will stick with the ability to hear.
80db is approximately “high urban ambient sound”, or about what you experience when you run your garbage disposal.
