Hacklet 126 – Teensy Projects
The Arduino has proved to be a great platform for electronics projects. The same goes for the Raspberry Pi. However, there are some projects that fall in the gap between these two options. Projects that need more memory or processing power than the ATmega microcontrollers have to offer, but not so much as to require a full Linux/ARM powerhouse. For those projects, there is the Teensy series. [Paul Stoffregen] created these lilliputian boards, and he’s been adding features ever since. The thousands of Teensy projects out there stand as proof that these little boards have been well received by the hacker community. This week’s Hacklet is about some of the best Teensy projects on Hackaday.io!
beatsWe start with [Jonathan Payne] and Beats by Teensy. Beats is an all in one music machine. A sampler, sequencer, and MIDI control surface; all powered by the Teensy 3.1 and the Teensy Audio Board. The audio board gives Beats the ability to record and playback 16 bit audio at a sampling rate of  up to 44.1 kHz. [Jonathan’s] inspiration came from devices such as the Akai MPC, and the MIDI Fighter. He utilized the incredible Teensy audio library on the software side. A project like this needs a serious case. [Jonathan] designed and built the perfect panel and case utilizing arcade buttons and a 128×64 LCD from Adafruit.
sabNext we have [RF William Hollender] and Teensy Super Audio Board. Not satisfied with CD quality 44.1 kHz audio, [William] decided to add a high quality audio codec to Teensy’s bag of tricks. He picked the CS4272 codec from Cirrus Logic. Capable of sampling rates up to 192 kHz, with a THD+N of -100 db, this codec should please all but the most discerning audiophiles. The high noise immune design doesn’t stop there though. [William’s] design isolated the Teensy and the rest of the interfaces from the codec to prevent ground loops. Connectivity is via standard I2S for the audio stream and I2C for control. This means the super audio board can be used with Raspberry Pi’s and the like.
spinoNext up is [Spino] with Spino. Teensy boards can do a lot more than just audio. Spino is a POV display with 32 spinning RGB LEDs. Spino can do more than just show pretty pictures though. With a Teensy 3.2 and bluetooth radio on board, the spino team is able to play games on their display. LEDs don’t work exactly like CRTs and LCDs though, so some color changes were necessary. The team utilized cell shading with a sobel filter to make Doom look even better than ever. The Teensy is even powerful enough to handle live webcam video sent over USB. The video is rendered and displayed on the spinning LEDs.
megsyFinally we have [Tim Trzepacz] with Megsy? A homebrew Teensy 3++. [Tim] is working on Megsy as part of his  residency at the Supplyframe Design Lab. Teensy’s have lots of edge mounted IO pins. There isn’t enough real estate for all the pins though, so some are routed to pads on the bottom. Megsy is a Teensy carrier board that breaks these pads out to pins. The idea is to solder the Teensy directly do the Megsy. As [Tim] calls it, “a poor man’s BGA”. The problem is getting the solder hot enough to melt while sandwiched between two insulating PCBs. [Tim’s] first attempt netted him a rather scorched Megsy board. Blacked as it may have been, the board did work!
If you want to see more Teensy projects, check out our new Teensy projects list. Notice a project I might have missed? Don’t be shy, just drop me a message on Hackaday.io. That’s it for this week’s Hacklet, As always, see you next week. Same hack time, same hack channel, bringing you the best of Hackaday.io!
9 thoughts on “Hacklet 126 – Teensy Projects
  1. I haven’t kept up to date on the Megsy, but why don’t try try through hole on the daughter board and prep the teensy with solder? Then just use a regular soldering iron.
    1. Thats what I did, but because of the pre-solder on the boards, they wouldn’t sit flat. Since it is impossible to heat all of the pads simultaneously with a normal soldering iron, I had to resort to using a super hot air rework tool to get the boards hot enough to melt the solder, which nearly melted the boards!
      Well, it is really all documented on the project page…
  2. If you love Teensy then preorder the new 3.5 & 3.6 on Kickstarter! I would buy one just to be able to ready the project updates alone. Paul is running a phenomenal campaign.
    1. The kickstarter has ended, you can preorder the new Teensies at pjrc.com
      I was one of the T3.6 beta testers. The K66 on the new Teensy 3.6 is an absolute beast :)
  3. I’ve got a tube of low temperature solder paste ready to do another test on the Megsy board, but I’m busy with the last week of the residency, so it will have to wait.
    I’m surprised that they didn’t mention the actual residency project that this is being used for: The NanoEgg Synthesizer!
    https://hackaday.io/project/11574-nanoegg-music-synthesizer
    I’m behind on updates because time is running out on the residency, but I finally completed a working keyboard that feels good to play. It’s bigger than the previous versions, which necessitates many updates to the box and everything else. Next week, I should be milling molds on the Tormach CNC mill, but I suspect I’m going to run out of time. Mold design is a very complex process, and CNC milling is not easily learned, either.
    I’m not sure how I am going to continue the project when our residency time runs out on Friday.
Leave a Reply to notarealemailCancel reply
