Jenkins Lights The Christmas Tree
Jenkins is open-source automation software that tries to automate parts of the software development process. When you submit code, for example, Jenkins will grab it, build the project with it and run any tests on it. If you have a large number of people submitting new code or data, Jenkins will wait and grab a bunch of the submissions to build. Depending on the size of the project, this can take a while, and if there’s a problem, you need to know quickly so that people aren’t waiting on a broken build. Email’s fine for this, but [dkt01] saw one of the desktop LED Christmas tree projects on Hackaday, and integrated it into his Jenkins system.
Like the other projects, WS2812b LED rings are used as the tree, and an Arduino Pro Mini runs the show, with an Ethernet LAN Module to communicate with the Python script that monitors the Jenkins build job. The Python script sends commands to the Arduino, which in turn lights up the LEDs. They light up green on a successful build and red if something fails, but during the build process, the LEDs show the current state of the build, tracking Jenkins’ progress as it builds.
Our previous Jenkins post used a big, red LED light that would light up if the build failed. [dkt01]’s build lets you know if the build is successful or has failed, but the build progress is a great addition.
5 thoughts on “Jenkins Lights The Christmas Tree
  1. Oh, please no Jenkins hacks, unless it involves hacking a server it is installed on with a real ax. Ours server room already smells like a Raid factory and after countless extermination efforts the bugs just keep showing up.
  2. Does anyone else want to have this flat, mount photodiodes between all the LEDs, mount it behind some semi-opaque perspex and turn it into a fancy colour wheel touch control.
Leave a Reply to DevopserCancel reply
