Ingenious Use Of 3D Printer Gives Simba The Mane He Deserves
Here at Hackaday, we love clever 3D prints. This amazing lion statue remixed by [ _primoz_], makes us feel no different. It is no secret that FDM 3D printers have come a long way, propelled by the enthusiastic support from the open source community.
However, FDM 3D printers have some inherent limitations; some of which arise from a finite print nozzle diameter, tracing out the 3D object layer by layer. Simply put, some print geometries and dimensions are just unattainable. We discussed the solution to traditional FDM techniques being confined to Planer layers only in a previous article.
The case in point here is a 3D printed lion whose original version did not fully capture its majestic mane. [_primoz_] solution was to construct a support cylinder around the head and form the actual hair as a series of planar bristles, which were one extrusion wide.
6d2b2c7253516ff7b54ee1d3be0aa6a7_display_large
This was followed by some simple post processing, where a heat gun was used to form the bristles into a dapper mane.
The result is rather glorious and we can’t wait for someone to fire up a dual extruder and bring out the flexible filament for this print!
[via Thingiverse]
7 thoughts on “Ingenious Use Of 3D Printer Gives Simba The Mane He Deserves
  1. Amazing project, a method I have used is using the printer as a printer pen with one hand on the extruder position knob and squeezing stands … Not very effective
    I’ll keep this in mind if I ever try it again, amazing work!
  2. Hmm, not being an arty type my immediate thoughts here are that you have an extremely low drag washable air filter once you have sprayed it inside with some sticky oil. Any diameter and length you want it so be.
Leave a Reply to RoGeorgeCancel reply
