Solving A Rubik’s Cube With Just Two Motors
We’ve all seen videos of Rubik’s cube champions who can solve the puzzle in less than 5 seconds. And there are cube-twisting robots that can solve the cube even faster, often in under a second. This Rubik’s cube solver is not one of those robots, but it’s still pretty cool.
The reason we like Dexter Industries’ “BricKuber” is not for its lightning speed — it takes a minute or two to solve the puzzle. What we like is the simplicity of the approach to manipulating the cube. Built from LEGO parts, including Mindstorms motors and a BrickPi controller, the BricKuber uses only two motors to work the cube. One motor powers a square turntable upon which the cube sits, while the other powers an arm that does double duty — it either clamps the cube so the turntable can rotate a layer, or it rakes the cube to flip it 90° on the turntable. With a Pi Cam overhead, the rig images all six faces, calculates a solution to the cube, and then flips and twists the cube to solve it. It’s simultaneously mind-boggling and strangely relaxing to watch.
All the code is open source, and we strongly suspect a similar and possibly faster robot could be built without the LEGO parts. You might even be able to build one with popsicle sticks and an Arduino.
11 thoughts on “Solving A Rubik’s Cube With Just Two Motors
    1. I guess, it’s easier to learn the maximum of 20 steps and a little bit of practice to solve every Rubik’s cube within a few seconds.
      1. Fewest move competitions are performed over an hour of unstructured cube analysis and manipulation and rarely achieve God’s number for 3x3s. The popular speedsolving stragegies (CFOP/Fridrich, Petrus, Roux) use methods that focus on an ordered process of solving via pattern recognition and memorized algorithms. Solving cubes this way typically ranges between 35 and 45 “moves” using a HTM (half-turn-metric) but requires years and years of practice.
Leave a Reply to GalaneCancel reply
