Meet The Modern Meat Man’s Modified Meat-Safe
Charcuterie is delicious — but is it hackable? When talking about the salty preserved meats, one might be more inclined to indulge in the concept of bacon before pondering a way to integrate an electrical monitoring system into the process. However, [Danzetto] decided to do both when he did not have anywhere to cure his meats. He made his own fully automatic meat curing chamber lovingly called the curebOS with the aid of a raspberry pi. It is basically a beefed up mini fridge with all of the bells and whistles.
This baby has everything.  Sitting on top is a control system containing the Pi. There are 5 relays used for the lights, circulating fan, ventilating fans, refrigerator, and humidifier all powered by a 5 amp supply — minus the fridge. Down below that is the 3D printed cover with a damper for one of the many ventilation fans that regulate the internal temperature.  To the right is a touchscreen for viewing and potentially controlling the system if necessary. The control program was written in Python for viewing the different trends. And below that, of course, is a viewing window. On the inside are temperature and humidity probes that can be monitored from the front screen. These readings help determine when to activate the compressor, any of the fans, or the humidifier for optimal settings. For a final touch, there are also some LEDs placed above the hanging meat to cast a glowing effect upon the prized possessions.
On top of that, [Danzetto] created a little app for this project that connects to a SQL database stored on his fridge Pi — not the edible one. This just lets him remotely access the system so that he never has to worry about the condition of those succulent beauties. If you are interested in learning more about the details of this project, I would start watching the Reddit posting for more updates in the next few days. The creator of the project is planning on putting together a build guide of sorts with open source software in the near future. Are you a foodie? Check out this sous vide Arduino project, or this automated smoker!
Let us know what other meat/food monitoring hacks you enjoy.
Thanks [Mark Walkom] for the tasty tip.
5 thoughts on “Meet The Modern Meat Man’s Modified Meat-Safe
  1. I’ve always had half a mind to convert my reflow oven controller mechanism into a sous-vide cooker. I’ve just never had enough inclination to google up a suitable water heating implement for such a contraption, not to mention do what it would take to make it better-half-friendly. In fact, that latter requirement is the major difference between the standard for a workbench appliance as opposed to a kitchen one. :)
  2. Hello PBorges, I am a Brazilian intusiastic and I was very impressed about your project. Did it work out fine? Can you share the codes that you used? Please get in touch. Regards, Felipe
Leave a Reply to eccentricelectronCancel reply
