[cyborgworkshop]’s youngest sister is a fan of a character in a popular video game (Thresh from League of Legends) who wields an iconic lantern with a mystical green glow. He resolved to make a replica of that lantern. Perhaps as a gift for the cherished family member? Certainly not! [cyborgworkshop]’s goal was the simple joy of having something “to lord over her.” Ah, ain’t siblings grand?
There were some interesting things learned in the process of making the ghostly green lamp. The first part of the build log is all about post-processing the lantern model, which was 3D printed at a chunky 0.48 mm layer height, but the rest is about getting the ghostly green glow to come out the way it did. [cyborgworkshop] used both glow in the dark paint and glow in the dark powder to really make the object pop, but the process involved some trial and error. Originally he mixed the glow powder into some clear varnish, and despite the mixture turning pink for some mysterious reason, a small sample spot appeared to turn out fine. However, after applying to the lantern and waiting, the varnish remained goopy and the glow powder settled out of the mixture. He ended up having to remove it as best he could and tried a heavy application of the glow paint instead. This ended up being a real blessing in disguise, because the combination resulted in a gritty stone-like texture that glowed brightly! As [cyborgworkshop] observes, sometimes mistakes end up being the highlight of a piece.
After more glow powder for highlighting, the finishing touches were a thin black wash to mute the powder’s whiteness, and a clear coat. The result looks great and a short video is embedded below. Oh, and if anyone has an idea why glow powder would turn pink when mixed into varnish, let us know in the comments!
[Jeri Ellsworth] once documented making glow powder from scratch, but for a more traditional approach to making things glow, this Nuka-Cola Vending Machine PC case cast some bottle replicas in resin mixed with UV-reactive blue dye, and bathed them in UV LED lighting to give them that soothing glow.
I don’t really know why, but I will say that is an effect that I’ve witnessed before. I used to be involved in industrial painting, and on occasion, when product was painted with matte clear coat, the coat would turn a some what translucent pink. Wait five minutes, and spray another coat, and it would turn back clear.
How interesting! I wonder what’s behind that. Your story suggests it might be something about the clear coat itself, rather than the glow powder.
Thick-film optical effects because of the difference in the index of refraction between the layers
Take white light. Remove blue and short wavelength green (ie blue-green). What is left, pink.
Its just the dye absorbing the blue chunk of the spectrum. What is left is red, with a bit of orange, yellow then decreasingly less green and blue. Result is pink.
You are correct.This is what most dyes works, yet time frame suggests reaction especially with inhibition of cure.What is in that dye only gods of alliexpress know for sure ;)
You can print in green glow PLA next time!
What a lovely surprise, I love hackaday! I think you guys are spot on about the pink color. I had printed this originally in glow in the dark PLA (and have the destroyed nozzle to prove it) but after finishing the glow wasn’t close enough to the surface to actually still shine. PETG and paint to the rescue :)
Why two substances, when mixed together, turn a certain color: Chemistry and quantum physics(which are one in the same on different scales)
