A Relay Calculator With DIY Neon Displays, Just Because
This looks like one of those projects that started out as a glimmer of an idea and led down a rabbit hole. But it’s a pretty cool rabbit hole that leads to homebrew neon seven-segment displays on a calculator with relay logic.
It’s a little thin on documentation so far, but that’s because [Mark Miller]’s build is one of those just-for-the-fun-of-it things. He started with a bag full of NE-2 tubes and the realization that a 3D-printed frame would let him create his own seven-segment displays. The frames have a slot for each segment, with a lamp and current limiting resistor tucked behind it; with leads brought out to pins and some epoxy potting, these displays would be hard to tell from a large LED seven-segment. Rolling your own displays has the benefit of being able to extend the character set, which [Mark] did with plus-minus and equal sign modules. All of these went together into a two-banger calculator — addition and subtraction only so far — executed in relays and vacuum tubes. Version 2.0 of the calculator regressed to all-relay logic, which must sound great.
We heartily regret the lack of a satisfyingly clicky video, but we’ll give it a pass since this is so cool. We’ll be watching for more on this project, but in the meantime, if you still need to get your click on, this electromechanical BCD counter should help.
3 thoughts on “A Relay Calculator With DIY Neon Displays, Just Because
Leave a Reply to RÖB Cancel reply
WordPress.com Logo
You are commenting using your WordPress.com account. Log Out /  Change )
Google+ photo
You are commenting using your Google+ account. Log Out /  Change )
Twitter picture
You are commenting using your Twitter account. Log Out /  Change )
Facebook photo
You are commenting using your Facebook account. Log Out /  Change )
w
Connecting to %s
