It’s Raining Chinese Space Stations: Tiangong-1
China’s first space station, Tiangong-1, is expected to do an uncontrolled re-entry on April 1st, +/- 4 days, though the error bars vary depending on the source. And no, it’s not the grandest of all April fools jokes. Tiangong means “heavenly palace”, and this portion of the palace is just one step of a larger, permanent installation.
But before detailing just who’ll have to duck when the time comes, as well as how to find it in the night sky while you still can, let’s catch up on China’s space station program and Tiangong-1 in particular.
China’s Space Station Program
Future Chinese permanent space station
Future Chinese permanent space station. Image by Craigboy CC-BY-SA 3.0
The space station that is currently on it way back to earth is a stepping stone in China’s long-range space station plan. They are on track to put up a permanent modular space station by 2022 with the first module going up in 2019. It’s to be around the size of the Russian Mir space station and have a ten-year design life. Central to it will be a service module with multiple docking ports and an EVA hatch. Permanently attached to that will be two lab modules. Crewed Shenzhou spacecraft and uncrewed Tianzhou resupply ships will be able to dock as needed.
However, before building the permanent station, they first had to test various technologies. In September 2011, China launched the Tiangong-1 space laboratory, followed in September 2016 by the Tiangong-2. These preliminary steps are much like Russia took with their Salyut space station program.
Both Tiangong-1 and 2 are first generation space stations in that they are single pieces with only one docking port. Having only one docking port means that they cannot be resupplied while a crew is present. That’s because the only docking port would already have a spacecraft attached to it as a lifeboat. A second-generation space station is also a single piece but with two docking ports, allowing for mid-mission resupplies and longer missions. The Chinese permanent space station will be a third generation, defined as a design consisting of multiple modules.
Tiangong-1
Tiangong-1 in orbit
Tiangong-1 in orbit. Credit: CMSA
The 8,500 kg (18,750 lb) Tiangong-1 was both a prototype space station and a space laboratory. As a prototype, it served primarily to test orbital rendezvous and docking. It’s made up of two cylindrical sections, a resource section with propulsion systems and solar panels, and a habitable section.
The habitable volume is 15 m3 (530 ft3) and includes control, communication and entertainment systems, exercise equipment, and two sleeping stations. A third crew member sleeps in the Shenzhou spacecraft in which they arrived. Cooking and toilet facilities are also in the Shenzhou.
The Missions
Exterior view of the resource module
Tiangong-1 had a two-year operational life during which three Shenzhou spacecraft docked to it. The first, the unmanned Shenzhou 8, successfully rendezvoused and docked in November 2011. The second, Shenzhou 9, followed on June 18, 2012, carrying a crew of three.
The initial docking of Shenzhou 9 was performed under automated control but six days later the crew performed another test by undocking and then redocking manually. The experiments were oriented around crew health and the effects of microgravity. They returned to Earth on June 29.
Shenzhou 10 carried three more crew the following year on June 11, 2013. They carried out further science and technical experiments, more docking tests, and did space station maintenance by replacing interior cladding and working on the seal rings. The crew also gave a video lecture and microgravity demonstrations to students throughout China. The mission lasted 15 days.
After the Shenzhou 10 mission, the station was put into sleep mode to save power while monitoring continued in order to test the longevity of key materials before its eventual re-entry.
Uncontrolled Re-entry
As stated above, Tiangong-1 is expected to re-enter the Earth’s atmosphere on April 1st +/- 4 days. The majority of Tiangong-1 is expected to burn up in the upper atmosphere, however, some pieces may reach the Earth’s surface.
Often in such case, the re-entry trajectory is guided so that those pieces come down in unpopulated areas. When the Russian Mir space station was deorbited in 2001, Russia used a Progress cargo spaceship to make sure it re-entered over the Pacific ocean. In March 2016, China announced that it had ceased data services for Tiangong-1 but also that it was under continued and close monitoring. However, according to ESA’s blog, there’s speculation that the station had ceased functioning and that ground crews no longer had the ability to command its engines to fire, hence, Tiangong-1 will undergo an uncontrolled re-entry.
Where The Debris Will Fall
Tiangong-1 re-entry area
Any debris will fall between latitudes 43° North and 43° South. But fear not, according to the IADC (Inter-Agency Space Debris Coordination Committee) anyone living in that area is 10 million times more likely to be struck by lightning than by any debris.
When You Can See It In Your Sky
Star chart for Kansas City April 1st
Before it re-enters, there may still be time to see it in the night sky and there are plenty of websites which tell you when and where to look. With no particular preference other than that it’s easy to use and does the job, here’s a link to heavens-above.com. In its list, click on “Change your observing location” to tell it where you are, and then click on “Home” to get the list again. Next, click on “Tiangong-1”. If you’re lucky enough to be in an area where it’ll be visible then you’ll see a list of viewing times. Click on one of the dates for a star chart telling you where to look at that time. Hopefully, it won’t reenter before March 31st because my next viewing opportunity is in the southern sky between 6:05 AM and 6:07 AM that morning.
If you have your own favorite viewing website or even a phone app, please share it with us in the comments below. And be sure to let us know if you do see it, or if you see the fireballs streaking across the sky on the day.
50 thoughts on “It’s Raining Chinese Space Stations: Tiangong-1
        1. No, that’s like 4 hours or more north of me. I live where the Corvettes are assembled and where John Carpenter used to live and where the film Halloween was based upon.
      1. Definitely isn’t…the radars that are used to track these are the same as the early warning radars (they mostly look for incoming ICBMs, but they are used part-time for debris tracking), they work in UHF bands, so the error is 10s of cm at least…
  1. Has anybody done the math on percent ocean versus percent land and percent populated land versus unpopulated land?
    This is clearly not going to fully burn up during reentry but it is also considerably most likely to just land in the ocean anyway, right?
      1. That graph makes no sense. It probably doesn’t include the ocean. And the units on the right histogram are also wrong. It would have to be %/km or something. It’s not corrected for bin size.
        1. It makes sense and it includes the ocean. You are correct that the units are missing for the vertical axis and the horizontal axis units would be better labeled as %/degree r %/km, but since the total area of the graph needs be 100%, it isn’t ambiguous. It LOOKS weird since the probability at max an min latitude is much greater than in the mid latitudes due to the orbit (well, it would be the same for any near circular orbit that isn’t purely equatorial or near polar, though this is about the most extreme choice)
          Yes, I had to look several times, but I have seen a lot (too many) of probability density graphs similarly labelled.
    1. That’s not really possible due to non-homogeneous distribution of people. Assuming 1 person /km² in this area and a killzone of 10 m² (it’s really just going to be a few parts that will be deadly), 10 µPersons will be killed on average. Seems not worth the hubub, considering that flu kills a few thousand every year.
    1. Eighty nine cents but it will take 3 weeks to put it in an envelope and 8 weeks to get there and then just send some Vietnam era transistor with all the nomenclature buffed off.
      That way people will know it is real Chinese goods ;)
  2. I was at school when it was raining american space stations.
    A well-known Australian entrepreneur offered a $20 million SkyLab insurance in case it dropped on our heads. And sure enough it did, in a way, as it crashed in Western Australia :)
  3. In fact, this is not even news. Objects are falling from space every month. Last month a Russian part fell on Corsica, Italy. Now the word ‘space station’ is used, everybody is suddenly excited.
Leave a Reply to Mr Name RequiredCancel reply
