If you can code, you can create an Alexa skill — the programs that allow an Amazon Echo or similar device interact with you. What if you can’t code or you are just too lazy to do all the setup? Amazon now has Blueprints that can help anyone make a skill. The only problem is the skills you can create are pretty limited. In addition, they are only available to your Alexa devices.
The idea is simple. You start with a template — OK, a blueprint. This is a model application that does something like giving you a compliment or a joke on demand. When you open the blueprint, you’ll see a list of things it can say. You can edit the list, including adding or deleting things. Then you name the new skill. In a few minutes, your skill will be live on your devices.
Continue reading “Blueprints Make It Easy To Make (Some) Alexa Skills”
