Single board computers have provided us with a revolution in the way we approach computing as hardware creators. We have grown accustomed to a world in which an entire microcomputer has become a component in its own right rather than a complex system, and we interface to them as amorphous entities through their exposed interfaces. But every pin or socket on a single board computer has something behind it, so following up on a recent news-inspired item in which we took a look at what lies behind the Ethernet jack on a Raspberry Pi, we’d like to continue that theme by looking behind more pins and interfaces. So today we’ll stay with the Raspberry Pi, and start with an easy target by taking a look down its audio jack.
All the main Raspberry Pi board releases since 2012 with the exception of the Pi Zero series, have featured a 3.5mm jack carrying line-level audio. The circuits are readily accessible via the Raspberry Pi website, and are easy enough to understand because of course all the really hard work is done within the silicon of the Broadcom system-on-chip. Looking at the audio circuitry, we’ll start by going back to the original Pi Model B from 2012 (PDF) because though more recent models have seen a few changes, this holds the essence of the circuitry.
The schematic above shows the audio circuitry from the first Raspberry Pi. On the left are inputs from a pair of BCM2385 PWM lines, and on the right is the audio jack. What is in the middle might seem quite surprising, this circuit uses only discrete components. Even that splits neatly into two sections, the diodes perform the function of protecting the input from harmful voltages that might come in through the jack, and the RC network is a filter. This last section is the interesting part, and deserves a more in-depth explanation.
PWM, which stands for Pulse Width Modulation, is an entirely digital way of representing an analogue value as a chain of pulses whose width is proportional to the analogue value being expressed. In itself it is not an analogue signal, though it is simple to convert to one by passing through a low-pass filter whose cut-off frequency is the maximum frequency of the analogue signal. So if we take a look again at the right hand side of the circuit, we see using the numbers from the right channel in the top circuit that R21 and C20 form a low-pass filter. The values of 270R and 33nF can be calculated to give a cut-off frequency of just below 18kHz, which is a sensible sounding value for an audio output.
The next two components are a high-pass filter, R20 and C48. This takes away any extremely low frequencies which might cause uncomfortable rumbling or damage to speakers. The values of 150R and 10uF can be calculated as having a cut-off of about 100Hz, yet again a sensible-sounding figure. The output from this pair of filters should be an acceptable audio signal, and goes straight to the 3.5mm jack.
Newer Pi, Better Audio
The more recent Raspberry Pi models have had a few changes in the audio department. The early boards had a low-ish audio level, and their frequency response could have been better. The newer version of the circuit adds a high-speed buffer chip to provide a lower-impedance source, and tweaks the filter values somewhat.
The low-pass filter’s 220R and 100nF now give it a cut-off of just over 7kHz, and the high-pass filter’s 100R and 47uF give it 33Hz. Both these values sound way off the mark, after all 7kHz is hardly hi-fi. But to imagine that the calculated cut-off frequency is a brick wall is to make a grave error. In fact that is better termed as a roll-off frequency, at which the response starts to decline. These revised values will give a rounded frequency response that still lets through plenty of high frequencies and stops plenty of low ones, but has an end result that doesn’t stretch too high above the audio range.
Thanks to some maths that torment electronic engineering students, the response of the low-pass filter should end at half the sampling frequency (at least) of the audio being played, to avoid unwanted distortion in the result. These values provide a better approximation to that figure, and thus make for a better quality audio output from more recent Pi versions.
This is a circuit that seems simple enough, yet there lurks a surprising complexity. It has plenty of uses beyond the Pi, because wherever you may use a PWM audio signal from a microcontroller or SoC you will need to replicate its functionality.
Does anyone know (or have a o-scope screenshot) of the “PWM” out is truly a PWM signal or a (much better) PRN (noise) modulation signal?Not complaining, but I am surprised at how shitty the audio quality is from the RPI. You can hear the aliasing plain as day – especially if the volume is low.
Have you tried enabling SDM mode for the audio? This uses noise shaping to push all the noise out above the cutoff frequencies of the RC circuits.
Just add audio_pwm_mode=2 to config.txt and you’ll find the audio much better
Fancy seeing you here!
HI Gordon, thanks for the tip. But since you probably are the Director of Engineering of the Raspberry Pi, and this article is specifically about explanation of the RPi’s analog audio output circuitry, as there are several conflicting advices in the comments, please could you bring some more definitive answer and actual facts about this electronic circuit design ?
Great article! I had to study the topic while working on ZeroPhone and adding audio to it – especially given that I use my ZP for music a lot, and I’m now working on adding out-of-the-box audio streaming sink support to it (AirPlay-receiver like). Some remarks:
– The 1.8K resistor on the output is not addressed – I personally would love to know about what it’s for. Loading the output somehow? Working as a high-pass filter as well?
– The 270/150 and 220/100 resistors also work as a voltage divider, dividing 3.3V output (either after a buffer or before it) into a ~1V signal, which was originally meant to produce “line-level” audio. I can’t really explain it well because I don’t know much about line levels, but here’s what Adafruit says: “R21 and R20 are voltage dividers to get the 3.3V signal down to about 1.1V max (that’s the max peak-to-peak voltage you want for audio line level.”
– The large output capacitor also works as the DC blocking capacitor – so that your line-ins/headphones only get AC and not DC waveforms they tend to dislike. Again, referring to the Adafruit guide ( https://learn.adafruit.com/adding-basic-audio-ouput-to-raspberry-pi-zero )
– The buffer not only provides a lower-impedance source – which is necessary after all, since even though Pi audio was never advertised for headphone output, people keep plugging headphones into it. The main problem is that 3.3V line is noisy because of CPU and peripherals’ activity. As a result of this, each time the CPU is doing something – like loading a new MP3 file from the SD card and parsing it – you hear noise in the headphones (unless there’s no active application doing anything with audio, then the snd_bcm2835 driver sets the audio output GPIOs low). To combat that, the filter is actually powered from a separate low-noise LDO (with 2.5V output on A+/B+/2B and 3.3V on 3B/3B+) – you can see it listed on the last schematic as AUD_3V3.
(Note that I personally like listening to the CPU noise – it’s kinda interesting to hear when your device’s doing something, like processing an SSH login. However, I assume that people building more consumer-facing devices don’t feel that way ;-P )
Hope this comment helps further explain the topic. One small point – I’m quite sad I can’t plug a Tindie link to my recently developed Pi analog audio experimentation breakout – yet =) While it’s likely inferior to an I2S DAC in terms of sound quality, it does allow you to add clean audio at the expense of 2 GPIO pins and minimal software problems. I’d publish it on Tindie by now, but I haven’t yet got one assembled (as I only recently got some 47uF capacitors from China). But mainly, I can’t wait to see if there are audible differences in frequency responses with different schematics – especially given that audio output is quite important for ZeroPhone.
1.8K resistor provides a DC path to ground on the output side of the capacitor. This gives an effective DC bias of 0 volts. The 1.8K is not critical, as it just needs to be >> the source impedance driving the output at signal frequencies, which it is.
The lesson here is if you are using your Pi as a music sound system you need to get an external USB DAC. This kind of conversion will never give you good sound.
Ethernet being already on the USB bus, any heavy network transfer will degrade your audio. . If one wants any decent audio output on the Pi, one have to use I2S, ideally with DMA (if you have some channels left).
Isochronous devices have guaranteed bandwidth, but it’s of course possible the CPU or SD card can’t keep up.
Or use the audio that comes through HDMI… That’s what I use for my webradio setup. The display I use for it ( https://www.pollin.de/p/display-set-ls-8-20-3-cm-8-hdmi-dvi-vga-cvbs-121059 ) has an undocumented (but labeled) analog stereo output with line level on the controller board. That’s where I grab the audio from to feed it into my AV receiver. Works as expected and sounds good.
The controller chip used is a MST6M182XST-Z1
Try telling mobile phone owners this. They are in uproar because they don’t understand bthe limitations on onboard audio stage. The inline DAC on the phones without jack sockets bring music alive, but they won’t ever get as far as hearing that, their preconceptions stop them.
LOL!
You were joking right?
Assuming you are talking about the move to USB C for headphone output.
If you don’t have a jack socket, those amazing DACs won’t even be used for headphones – only the speaker output. And most phones use class D amplifiers to amplify the speakers, which some would say see inferior and cause distortion – especially if it’s using PWM rather than PDM generated with a delta sigma modulator. It doesn’t matter how good the DAC is if an inferior amplifier is used.
USB C is usually digital output only, even to headphones, so almost always, the headphones will require own DAC. Quite often they cheap out on the DAC. Often it just isn’t a good quality DAC because it doesn’t convert the signal to analog without noise, or it hasn’t got good dynamic range, due to bit depth.
Often DACs just don’t have the power to drive certain headphones, so they should have a separate headphone amp chip, but USB C headphone manufacturers don’t always bother adding one in the design. And even if they did add an amp to drive the headphones, it might not be a good quality one, or even one designed for headphones. They might have used a low quality amp that isn’t designed for headphones, and isn’t even designed for high quality audio at 10K impedance.
Phone manufacturers cheaped out so they didn’t have to add those chips in phones at all, or so they could increase sales of USB C headphones also made by the same phone manufacturers.
Has anyone tried using the PWM to control some half bridge drivers for directly driving speakers? That should theoretically work, just limited in quality since the Pi’s PWM output is not particularly high resolution.
Speaker is not a motor, don’t treat it like one. Speakers have complex impedances and really, really hate square waves. However H-bridge configuration is done by bridging two class D amplifiers with proper output low-pass filters.
Many class D amps use a H-bridge configuration. And in “filterless” class D amp chips the speakers get the square waves, they are not asked if they like it. :-)
Ah yes, converting square waves into something analogue through the speaker’s own physical inertia. I know that shoddy method very well.
If you enable the SDM audio (other people have mentioned in the comments), it runs the PWMs with a ~780 kHz carrier and 7 bit resolution. This could go straight into an off-the-shelf H bridge driver.
Noise shaping pushes the quantisation noise up out of the audio band. The quantisation noise floor ends up around -95 dB, which is more or less CD quality. I remember reading about this in a thread on the Pi forums.
Wrt filtering, you can get away without it (speakers only have a finite bandwidth anyway), but if you are really looking to gild the lily, you could build a simple passive filter like an LC Butterworth. Speakers are complex loads, you will want to do some LTSpice when you design this circuit.
” high-pass filter’s 100R and 47uF give it 33Hz.”
Errrm. No! The HP filter is the 4.7uF together with the 1.8K in parallel with the load (more exact, there is some source impedance over there as well, but will be well below the 1.8K, so that should be dominant). So the corner should frequency be much smaller in case you use active speakers.
You mean, 47uF – not 4.7uF, right?
yup, my bad. 47. C60 and R60 on the schematic.
Electrobob, you’re right. Just imagine a case of infinite load impedance (at the older Pi scheme) – the “highpass” corner frequency limits to zero! The circuit analysis idea is principially bad. The right analysis says, that there’s a PWM smoothing and level adjusting first order lowpass in a form of a resistor divider R21 and R20, together with a C20 – and a simple DC decoupling capacitor C48. No highpass at all.
At the “PI3” there is somethig looking like a highpass, made of C58 and R61 – but its corner frequency is out of the audible band. Thus, the correct view is the DC decoupling capacitor again – and a “DC zeroing” resistor at the output to eliminate the “plug in” pops.
Oh but please Jenny, everyone already knew about the pi pwm audio?
Are you having a bad day?
I didn’t. Well I knew it was PWM and filtered and generally rubbish in the noise depot, but didn’t k ow how the circuitry works. Was good to read up on it.
Doesn’t the Pi also have I2S audio input and output? In combination with a good A/D D/A converter or at least an S/PDIF converter it should be possible to get some really good audio into and out of that.
Yes it does, and there are several audio boards available – search for HiFiBerry, Pi-DAC, Wave Shield, PiSound…
Basically it uses a 1bit DAC.
Not just a 1-bit DAC, but the second-simplest to explain and second-worst-sounding kind of 1-bit DAC.
Delta-Sigma converters are also 1-bit DAC, and you can get really nice results out of a 5th order one.
You can enable SDM audio on Pi by putting audio_pwm_mode=2 in your config.txt
This runs a sigma-delta controller with noise-shaping error feedback on the VPU (i.e. in software!). You get about 15 1/2 bits of resolution by enabling this.
I’m kind of a noob to electronics (teaching myself), but I really don’t think the Nyquist rate applies here (unless the output is intended to go into something that is sampling at ~14khz). Every class D amplifier schematic I’ve seen has a low pass filter with the cutoff frequency well above 20khz so that the frequency response is flat throughout the audio band.
The lowpass filter here seems terribly low. I’m guessing it’s because the PWM can’t switch at a proper high frequency?
For a couple of bucks (and I am being generous here), I can get a USB sound card delivered to my door, that also includes the USB connector, a couple of female jacks, and an LED, all inside of a plastic case.
I wonder how much does Adafruit save on each RPi by using a PWM instead of a dedicated chip.
1) Adafruit doesn’t produce RPis, you might be thinking about Raspberry Pi Foundation 2) those USB cards don’t have good sound, as I’ve found out 3) it’s probably a whole bunch cheaper – especially initially, with Pi 1A/1B, when it only cost the same as adding 5 items to the BOM 4) there’s only one USB host port, so audio would require a USB hub on a Pi A, as opposed to simply employing two by-default-unused PWM channels.
1) I stand corrected, thanks.
2) On the other hand, I’m completely satisfied with mine: I can play MP3 files (using a TA2030 amplifier and a couple of speakers) and not distinguish them from a CD.
3) It can’t believe it’s “a whole bunch cheaper” when the full item (plus other parts you would not need) does not cost more than a couple of bucks (literary).
4) It does not have to be USB-based, I’m sure there are other methods to connect a DAC.
So put that in the first two #RaspberryPi’s and I shall buy it.
Ok the foundation will put the new circuit into the old Pis, once this baby hits 88 MPH
The 3dB point is actually determined by 220//100 ohms and 100nF. So its actually 68.75 ohms and 100nF, which gives
23kHz
Unfortunately the explanation of the filters is not correct. The low pass filter has the impedance of the voltage divider (parallel connection of the 2 resistors, 96 Ohm) as working resistance. This gives a corner frequency of 96kHz.
The 10µ cap is only for DC blocking, it’s working resistance as a filter is the input impedance of the following stage (e.g. 47kOhm) or headphone (e.g. 32 Ohm). So it is no well defined filter.
Also, a 32 Ω headphone voice coil is not interchangeable with a 32 Ω resistor. It’s electrically inductive, and mechanically resonant.
However, when you consider the board space and BoM cost of one of these boards, it’s a pretty good solution.
Look at the price of a 3.3V rail-rail input-output dual op amp on your favourite distributor. Then ask what you would have to sacrifice on a *computer* where parts, board manufacture, board assembly, testing and margin all add up to $35 plus tax.
Also ask: is it worth it, when most use cases are covered by HDMI audio?
The rPi’s headphone jack is so shitty, it’s actually an impediment to use. At that point, yes, it’s worth it to have a better one.
Have you tried turning on the good audio?
audio_pwm_mode=2 in config.txt
If not then why are you complaining about shitty audio?
There has to be a tradeoff here; otherwise, what would be the reason for a switch like this? I can’t see a manufacturer saying “We’re going to configure this to have shitty output by default, but we will provide an option for the customer to change it, if they can figure it out.” I’m guessing that there’s some cost elsewhere in setting it to “2”, but I haven’t found an explanation of it yet. It also makes me wonder, if 2 is good, wouldn’t 3 be better?! :)
I suspect the real reason the original PIs had that silly RCA connector was so they could display video on any TV the user might already possess. HDMI displays cost many times the cost of a PI, and especially in 2012 might not have been available to some of the target population.
Pete’s original design was only meant to be a line-out and suffered noise due to the fact the IO bank driving the PWM signals was noisy (as others have pointed out).
My goal for the B+ was to reduce the output impedance so that headphones were usable (so had to drive 32R ‘phones at acceptable volume) and to cure the switching noise.
For the record the correct analysis is (looking at the AUDIO_L channel of the Pi3):
– The buffer is driven from a low-noise supply (LDO) to avoid coupling general GPIO bank noise into the audio.
– R16 (220R) in parallel with R17 (100R) drops the 3V3 output to ~1V and provides an output impedance of R16//R17=68.75R which forms a low pass filter with 3dB point at ~23kHz with the 100n cap.
– C58 (47u) is sized to give adequate bass response when driving low impedance (32R) loads (and was the largest already-used cap value).
– Each buffer can source/sink up to 25mA but at that level dissipates quite a bit of power – max DC output current was set at ~10mA (3.3V/(220R+100R)).
– R61 (1.8K) is simply to make sure the line-end of the output cap is biased to 0V so avoid clicks/pops when plugging in an audio sink. As has been pointed out this just has to be significantly larger than the output impedance of 68.75R – 1.8K was just a convenient already-used value.
As others have mentioned headphones both change the response of the filter and provide a complex load and therefore can’t be simply equated to a 32R resistor – however in practice it works well (and of course it was tested with various sets of headphones to make sure human ears approved!).
A side note – I removed the BAV99 protection diodes as these are not really necessary – the energy of an ESD strike will easily be buffered by the R and absorbed by the large Cs in the signal path well before it can do any damage to the upstream silicon.
I would definitely suggest adding:
audio_pwm_mode=2
to config.txt to enable the Sigma-Delta modulation mode which gives near CD quality output.
James, thank you and Gordon for having responded to the call, it’s excellent to have those insights direct from RPi engineers in the discussion !
The Sigma-Delta modulation mode is nice to have. I’ve found this topic where it is detailed : https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=195178
I was looking forward to study the software implementation in the driver (like the noise shapping) but couldn’t find it, looks like it’s in the firmware which is closed source… Still, your developper [jdb] gave some hints : https://www.raspberrypi.org/forums/viewtopic.php?t=171588
Gosh. It doesn’t get much closer to the horse’s mouth than that! Thank you very much, I really appreciate your coming back with the inside story on what I tried to describe from the outside.
No problem – despite apparent simplicity the circuit is actually a result of some careful design decisions, it’s a fun (and educational) one to analyse!
Thank you, it’s awesome to have an answer directly from the source!
Yeah, this post has lots of problem…. Mostly corrected by the comments.
The problem though is that it’s impossible to determine where the “correction” actually is. There are a lot of people posting their revisions but without acknowledgement from the OP it’s unknown what the real answer is. Is there an authoritative answer here? And I’m trying to remember the original question now… Oh yeah, what the real performance characteristics are of the audio port. To my ears, it doesn’t sound like there’s much in the high end, but I could say that about day to day conversations as well! I’m mystified as to why later gen RPis would have lowered the lowpass corner frequency from 18k to 7k, and if that’s actually true. I don’t see an authoritative answer here.
The analysis of the RPI 3 Audio output stage is incorrect a more accurate estimation of the bandwidth is 1.9Hz to 24kHz..
How so? The output impedance ignoring the 47mF capacitor is approximately 70 Ohms (parallel combination of 220, 100 and 1800) with the 100nf that gives an upper corner frequency (-3dB) of 24kHz (1/(70*100e-9) radians per second, divide by 2Pi to get Hz). The low end is determined by the 47mF coupling capacitor and the 1.8k giving a corner frequency of 1.8Hz (1/(1800*47e-6 radians per second). I am making two assumptions here, firstly the buffer before the 220 Ohm resistor has zero output impedance or at least small compared to 220 Ohms. The higher the actual impedance is lower the upper frequency -3dB point; however there is a lower bound set by the 100 Ohm resistor. I have also assumed infinite input impedance for the item plugged into the 3.5mm jack. The lower the impedance here the higher the low end -3 dB point. If a typical stereo amplifier line input is connected (input impedance > 10k) then this will have a minimal effect on the lower -3dB point raising it to about 2.2Hz. It is desirable that this frequency is much lower (e.g. factor of ten) than the minimum frequency that is intended to be reproduced. This is because ceramic capacitors can have some voltage dependency in their capacitance and hence produce some harmonic distortion at low frequencies.
Other comments about the RPI audio quality may not be entirely justifiable either. I am not suggesting that It will satisfy a true audiophile, particularly those who like vinyl; however the sound quality may be better than you may think. It all depends on the modulation scheme being used. For a project I am developing I am intending to use Analogue Devices’ SSM2035 class D amplifier to allow an RPI to drive about 1W into an efficient 8 Ohm speaker. The class D amplifier uses delta sigma modulation and has a claimed THD approaching 0.01% and a no signal noise level of -98dB with respect to the amplifier’s maximum power of 1.4W. A one bit DA converter when properly designed can produce extremely good results, the evidence being their use in some very expensive CD players of the past.
I saw somewhere an estimate that the RPI output voltage was of the order of 1.1V RMS this is also incorrect. Assuming the buffer stage swings completely from 0 to 3.3v, the 220 Ohm and the parallel combination of the 100 Ohm and 1.8k form a voltage divider, this limits the voltage swing to a maximum of 993 mV (3.3 * 100 || 1800 /(220 + 100 || 1800)), when converted to AC RMS volts divide by 2 * sqrt (2), we get 350mV. This is about -9 dB with respect to the 1V RMS that typical line outputs on audio equipment produce and hence the higher gain settings required.
Exactly. I got the same result. 1.8 Hz and 24 kHz.
Is there a way to control the two PWM lines used for the audio output directly – without the use of any audio system like ALSA ? All I need is to be able to pull the lines high or low like a GPIO pin from some software.I want to use the audio out jack to provide clicks to synchronize sequencers and synthesizers, but keep it synced with MIDI clock. This means the lowest latency possible and I want to avoid any latency caused by buffering.
