Twitch Plays Battling Robots?
Audience interaction reached an all-time high in 2014 with Twitch Plays Pokemon, an online gaming stream where viewers were able to collaboratively command an emulated Game Boy playing Pokemon Red. Since then, the concept has taken off. Today, we see this extended to robots in the real world, with [theotherlonestar]’s Twitch Chat Controlled Robots.
The build is one that takes advantage of modern off-the-shelf components – an ESP8266 provides the brains, while a Pololu Zumo provides a ready to go robot chassis to save time on the mechanical aspects of the build. An L298N dual motor controller then handles motive power.
The real ingenuity though, is teaching the robots to respond to commands from Twitch chat. The chat is available in a readily parsable IRC format, which makes programming around it easy. [theotherlonestar] created a command set that enables the robots to be driven remotely by stream viewers, and then outfitted the ‘bots with hammers with which to fight, as well as a fedora to tip, if one is so inclined.
It’s a cool build, and one which shows further promise as Twitch continues to reduce stream & chat latency. We look forward to seeing future battles, but the first one already excites.
Interested in where it all began? Check out our Twitch Plays Pokemon coverage from way back when. Video after the break.
3 thoughts on “Twitch Plays Battling Robots?
  1. Wow. FIrst time I got a project up on Hackaday! If you want to join in on the fun you can see my schedule in my panels. Next stream is tonight (8-8-18) at 7pm eastern. Let me know what you think!
Leave a Reply to Other LonestarCancel reply
