Simple Ultrasound Machine Shows The Skeleton Lurking Inside Us All
That first glimpse of a child in the womb as a black and white image on a screen is a thrilling moment for any parent-to-be, made possible by several hundred thousand dollars worth of precision medical instrumentation. This ultrasound machine cobbled together from eBay parts and modules is not that machine by a long shot, but it’s still a very cool project that actually gives a peek inside the skin.
The ultrasound transducer used by [stoppi71] in this build has an unusual source: a commercial paint-thickness meter. Cue the jokes about watching paint dry, but coatings measurement is serious stuff. Even so, the meter in question only ran about $40 on eBay, and provided the perfect transducer for the build. The sender needs a 100V pulse at about 5 MHz, so [stoppi71] had some fun with a boost converter and a 74121 Schmitt-trigger one-shot driving a MOSFET to switch the high voltage. On the receive side, the faint echo is sent through a three-stage amp using AD811 op amps before going through an LM7171 op amp acting as a rectifier and peak detector. Echos are sent to an Arduino Due for display on a 320×480 LCD. The resolution isn’t great, but the video below shows that it’s enough to see reflections from the skin of [stoppi71]’s forearm and from the bones within.
[stoppi71] says that he was inspired to tackle this build by Murgen, an open-source ultrasound project. That project got further refined and entered into the “Best Product” category in the 2018 Hackaday Prize. We like that because focusing on turning projects into products is what this year’s Hackaday Prize is all about.
11 thoughts on “Simple Ultrasound Machine Shows The Skeleton Lurking Inside Us All
      1. You reckon a person would be willing to admit they owned that? :eek: Personally I would be far to embarrassed to admit I may have a hand in writing or performing such a cacophony.
    1. So you’re judging a project based on the music they used in a video? That is very shallow of you, akin to judging a person’s character based on the paint color of their vehicle.
      Get a grip, John. If you don’t like the music, simply admit it’s not to your taste and turn the volume down.
  1. > That first glimpse of a child in the womb as a black and white image on a screen is a thrilling moment for any parent-to-be, made possible by several hundred thousand dollars worth of precision medical instrumentation.
    Last I checked, new medical grade ultrasound imaging machines were available for under $10K
    1. My wife is a sonographer and her office just got a brand new GE unit and it ran them roughly 400k. The really cheap units work but the images they produce are of very poor quality.
  2. This is a fascinating project, and the article captures the creativity behind it well. Repurposing a paint-thickness meter as an ultrasound transducer is especially clever, and it’s impressive how much can be achieved with accessible, low-cost components.
    I also appreciate the clear distinction between experimentation and clinical use — it highlights the value of open-source, hands-on projects in making complex imaging technology more understandable and inspiring. Thanks for the writeup!
  3. That’s a pretty neat collaboration you came up with just from Ebay parts! I work in the field of radiation. I’m curious what the radiation exposure would be from the invention you created. I’m sure it’s not much but I do wonder about the amount it may or may not put off.
Leave a Reply to Barbie SmithCancel reply
