Mac Plus Becomes A Vector Display
The vintage Macintosh all-in-one computers were a design icon, as well as being highly useful machines in the 80s and 90s. In the decades since, they’ve been used for everything from web servers to aquariums, but that’s not all. [Arcade Jason] decided to grab an old Macintosh Plus and turn it into a vector display.
The hack starts with the opening of a Macintosh, which naturally requires a long screwdriver with the right tip. Setting the stage for things to come, this is achieved by soldering together a couple of existing tools to get the reach he needs. [Jason] then proceeds to install a brightness control for the main electron gun, as well as deflection drivers and a spot killing circuit. Everything is done with the intention of the hack being reversible, as [Jason] didn’t wish to sacrifice a good Macintosh Plus just for the sake of having some fun.
For those unfamiliar with vector cathode-ray displays and the manner in which they are driven, [Arcade Jason] does a great job explaining the basics. A set of magnetic coils is used to alter the trajectory of an electron fired at the screen. If you aim those electrons in ordered lines from left-to-right, top-to-bottom you’ve created a raster display. If you instead guide the electrons to follow the shapes you want to appear on the screen you’ve created a vector display.
We can’t help but feel this would be a hilarious way to troll at a demoscene meetup. We’ve seen [Jason]’s vector work before, too — like this impressive color Asteroids hack.
8 thoughts on “Mac Plus Becomes A Vector Display
  1. Mac Plus tubes are actually almost perfect replacements for Vectrex tubes! I know which is more important to me… :)
    Also, as this would perfectly fit into the Wild section at any demoparty, I’m not sure it counts as trolling.
  2. The roadblock to making vector displays has always been the need for a new, custom-wound yoke.If Arcade Jason had found a way around that, it would be game changing. But he hasn’t, so the fact that he does to a Mac what people have done to other CRTs is not that special.
    1. Agreed, except maybe since it’s a specific tube/application that people might be able to source somebody might be able to prefabricate and sell the yoke.
    2. i have a video on my channel showing how to wind a custom vector yoke . if winding a custom yoke is too difficult there is another way . a custom vector circuit ban be made as well. the trick would be to run one side at a higher voltage to compensate the additional windings .
      1. If it’s possible to make a vector display without winding a coil, that would be great! If someone made a kit that could just be installed in, say, a Mac Plus and turn it into a vector display, I’ll bet it would be fairly popular. Especially if paired with the Vectrex logic board clone someone recently made.
        (Alternatively, if someone were to “mass produce” vector coils for a Mac Plus, that would be very appealing too.)
      2. Jason, I don’t think I’ve heard you mention that before. Have you posted more detail about this idea anywhere? It definitely sounds like something worth pursuing, indeed perhaps worthy of your next project :-)
Leave a Reply to ROBCancel reply
