A CNC Hacked Together In Pajamas
Sometimes you just gotta sit down and hack something together. Forget the CAD and the cool software toys; just hammer away until you have something working. That’s how [bobricus] ended up with this cute little laser engraver anyway.
For under $300 US of parts and a few nights working in his pajamas, the aptly named, pajama micro laser engraver is a pretty nice little machine for its class. Not having the space for a full size machine and not necessarily needing its capabilities he aimed to produce something compact.
The frame is aluminium extrusion, the movement is core-XY an H-bot on linear rails, and it appears to just be a grbl board with a Chinese laser module on it. He took a bit of care to make the frame a cube which allows him to easily vent the fumes from the little unit. There’s even a small air pump to blow the off-gas from the cutting away from the laser.
All in all a nice little hack useful for all sorts of things from solder masks to cutting wood veneers. You can see it zipping around in the video after the break.
11 thoughts on “A CNC Hacked Together In Pajamas
    1. My guess would be someone started off phrasing it as “designed” and changed their mind to “hacked” but forgot to delete the “designed” part? “A CNC HACKED TOGETHER IN PAJAMAS” sounds more right than what we got.
Leave a Reply to SaabmanCancel reply
