LEGO Microtonal Guitar: Building Blocks Of Music Theory
Is there anything LEGO can’t do, aside from turning to a soft gelatin when a human steps on one? The incredible range of piece sizes that make them such versatile building blocks extends their utility far beyond the playroom floor, as [Tolgahan Çoĝulu] demonstrates with his LEGO microtonal guitar.
His LEGO what now? If you’re in the western world, microtones simply refer to those that fall between the 12 semitones-per-octave shackles of the western scale. Microtones are smaller than semitones, so they can bring a richer flavor to music, as evidenced in eastern cultures. In the past, [Tolgahan] has made microtonal guitars with fixed and adjustable frets using standard fret wire. After his young son copied his design in LEGO, he decided to bring it to life.
[Tolgahan] and a friend designed and printed a compatible base plate fingerboard and glued it in place on an old classical guitar. Then he and his son spent hours digging through their hoard to look for 1x1s and other 1x pieces to build up the fingerboard.
Here’s where it gets really interesting — they printed a ton of special 1×1 pieces to build up the moveable frets. Since they’re 1x1s, they can also be used to teach music simply by moving them around to the notes of the scale or song being taught, no matter the hemisphere it comes from. Pluck your way past the break to watch the story play out and hear this LEGO guitar for yourself.
If [Tolgahan] and his son had used machine learning to sort their LEGO, it probably wouldn’t have taken so long to find all those 1x1s.
Via Adafruit
8 thoughts on “LEGO Microtonal Guitar: Building Blocks Of Music Theory
  1. Great article, and ive always enjoyed this type of sound but didn’t quiet know what general style was/the system being used/ the appropriate place to start as my only real exposure was through Metal band who’s members where Armenian-American (System of a Down).
  2. One of the dollar stores, can’t remember right now if it’s tree or rama, has a self adhesive “compatible with major brand” stud strip, if anyone wants to just glob that onto a cheap guitar and screw around.
  3. It looks like the distances between the 1st and 2nd and 2nd and 3rd frets are the same. No way this guitar plays in tune. Capo-like moveable frets added on to a standard fretboard would make more sense. Sitars do something similar.
    1. Nah they’ve been calculated to some degree, you can see some extra length on the printed base behind the 1st fret. If you check this guy’s other videos he clearly has a lot of experience with microtonal guitars.
Leave a Reply to StuCancel reply
