Design And Construction With Copper Pipe
Copper is a material with many applications; typically, it’s used for electrical wiring or in applications where good heat conductivity is a requirement. However, it can also make for an attractive material in furnishings, which [Andrei Erdei] decided to explore.
A render of the coffee table design, exported from OpenSCAD into Fusion360.
[Andrei]’s work began in OpenSCAD, where he wrote scripts to enable the quick and easy assembly of various designs. The modular nature of commercially-available copper pipe and fittings allows complex structures to be assembled, particularly if you’re a fan of 90-degree bends. The final renders of some of these designs are impressive, with the coffee table design a particular highlight. Staying conceptual wasn’t enough, however, so [Andrei] set out to build one of his designs. Constructing a table lamp shroud out of copper parts was successful, though the real components have flanges and other features that aren’t represented in the rendering.
It’s a project that shows the value of tools such as OpenSCAD to aid the design process before committing to cutting real-world materials. While the designs on screen aren’t perfect representations of what’s possible in reality, it still proves to be a useful guide.
We’re a fan of the aesthetic, and would love to see more done with copper pipe as a construction kit. Global ore prices may limit experimentation, however. Alternatively, you can always harvest the metal from scrap!
21 thoughts on “Design And Construction With Copper Pipe
    1. I agree Emyr Not only that but a table, a desk… Copper is NOT a very light-weight material. If you wind up moving once or twice, the appeal will very soon be lost.
  1. Back in my radio days I built J poles out of copper pipe. Some of them were pretty spiffy looking.
    Back in my mid IT days when people use 10 base 5 Ethernet with vampire taps and AUI connections to the computer, but most of the Ethernet cards also supported 10 base 2, I had a rather elaborate sculpture built out of the unused Tees and terminators that used to ship with the cards. The 10 base 2 was easier in theory but people would take their computers and just leave the cables dangling and hose that entire network segment until we could get their office door unlocked and fix it. I still have a big cluster of that stuff someplace. It is oddly fun to play with.
    1. Others have left good tips. Another is to heat the joint on the side opposite where you apply the solder. Once the heat reaches the side you’re applying solder to, you know it’s hot enough.
  2. About sweating copper pipe troubles.
    A (lack of a) large enough heat source is one common problem I’ve seen.
    The other big one is surface preparation.
    This part is as simple as any other soldering job.
    Be sure that your cleaning tools,( sandpaper or wire brush) are clean. No dirt, grease, rust or other contaminates. you can’t use the kit brush for scrubbing tires or grout, dirt, glue etc….
    And you can’t use the sandpaper for cleaning paint, rust, same rules apply here.
    When either one gets grubby, discard or relegate them to the general usage box, never to be used for solder work again.
    Otherwise you just keep spreading the contaminates all over the copper and solder wont flow and stick.
    Dirt, grease, paint and skin oils all will foul our soldering efforts on the electronics bench and just keep in mind they do the exact same thing with plumbing.
    Just like with wiring or circuit boards, once you clean the copper, don’t handle the cleaned areas again. Hands just contaminate them.
    Now go grab some plumbing bits, a new brush & sandpaper, then give it try!
  3. Now you know copper is anti-virus, it is going to be more and more railing, guard rail, and the like.
    In fact the first use for this purpose in recorded history is in the time of Moses. In Exodus of the OT, brass (or bronze) were used in all the washing and sacrificial furniture since three thousand five hundred years ago.
    Then the Lord spoke to Moses, saying: “You shall also make a laver of bronze, with its base also of bronze, for washing. You shall put it between the tabernacle of meeting and the altar. And you shall put water in it, for Aaron and his sons shall wash their hands and their feet in water from it. (Exodus 30: 17-19)
    Not just the basin, but also the pots, pans, and other things:
    “”Moreover, the Chaldeans broke up the bronze pillars and stands and the bronze Sea in the house of the LORD, and they carried the bronze to Babylon. They also took away the pots, shovels, wick trimmers, dishes, and all the articles of bronze used in temple service.” (2 Kings 25:14)
    With all these blood splatters and animal fluid of daily sacrifice, all these biohazard dangers were never a problem during the time of the first and second Temples.
Leave a Reply to Marlene KellyCancel reply
