Rapid Prototyping System Gives Wheels To Wearables
Wearables are kind of a perplexing frontier for electronics. On the one hand, it’s the best possible platform for showing off a circuit everywhere you go. On the other hand, the whole endeavor is fiddly because the human body has no straight lines and moves around quite a bit. Circuits need to be flexible and comfortable. In other words, a wearable has to be bearable.
[Konstantin], [Raimund], and [Jürgen] have developed an intriguing system for prototyping e-textiles that opens up the wearables world to those who don’t sew and makes the prototyping process way easier for everyone.
It’s a small and portable roll-on ironing device that lays down different kinds of custom ‘tapes’ on to textiles. The conductive fabric tapes can be used as touchable traces, and can support components such as flexible e-ink screens and solar panels. Some tapes provide single or multiple points of connectivity, and others are helper substrates like polyimide tape that multiply the possibilities for complex circuits.
The device uses a modified soldering iron to transfer the tapes, which are loaded onto 3D-printed spools that double as the wheels. Check it out after the break — there’s a 30-second tour and a 5-minute exploration of the whole process.
Everyone needs to prototype, even the seasoned stitchers. The next time you’re thinking in thread, throw some magnets into the process.
7 thoughts on “Rapid Prototyping System Gives Wheels To Wearables
  1. They will follow the Gillette razor tactic and give the iron away, but charge through the nose for the consumables (the strips with the “wires”)
    1. Shortly followed by “counterfeit” consumables, followed by yowling in the press, a wrongheaded DRM Keurig-lock, a bit of tape and a printed label and eventually something useful and economical. Eventually.
      1. Don’t tempt them.. nfc tags in the blade cart, and won’t attach without passing the nfc tag check will also limit life…
  2. I think of a watch as a “wearable”, a Google Glass as a “wearable”, a PipBoy 3000 as a “wearable”, even a vest that has heating elements and a battery pack is a “wearable”. But cloth items with LEDs?….
    1. Be patient, it’s just like when 3d printing became affordable/popular: everyone was printing the Eiffel Tower or whatever. There are some pretty amazing examples of wearable electronics out there already; check out burning man costumes, el-wire dancers, and the evolution of the Mi Mu gloves by musician Imogen Heap and her team.
  3. Just make ribbon cables a fashion statement. No need to go for the “Arts & Craft” approach. Much better electrical characteristics and easier to handle. There are all kinds of IDC connectors that are designed to snaps onto ribbon cable. Want a belt buckle, make a DB-25 M/F pair.
  4. The project looks interesting but hard to manually craft the rolls. If they take it further and manufacture the stickers an rolls in a factory and then sell them as a complete kit to try different things, I think that would be interesting.
