Fire Pit Burns To The Beat With Bluetooth
Humans have several primal fascinations and perhaps two of the biggest ones are fire and music. While you can picture some cavemen and cavewomen sitting around a fire beating on sticks for rhythm, we think they’d be impressed if the fire danced along with the music. Through the power of Bluetooth, that’s exactly what [Random Tech DIY’s] new fire pit does.
Technically, this is called a Rubens tube, and while it’s an old technology, the Bluetooth is a certainly a modern touch. As you might expect, most of this project is workshop time, cutting MDF and plastic. The audio system is off-the-shelf and drives some car stereo speakers. The results looked good, and although it always makes us nervous building things that carry propane gas, it seems to work well enough from where we’re sitting.
We had to wonder what things you could change that would affect the display. Changing the number of holes, the diameter of the holes, or the gas pressure, for example, would certainly change how the flames look and react to the sound waves.
We have seen other Rubens tube projects, of course. However, we were really interested in the use of these as crude oscilloscopes before the availability of cathode ray tubes. We’ve seen a modern take on that, too.
3 thoughts on “Fire Pit Burns To The Beat With Bluetooth
  1. The vibrating flames are pretty annoying for my eyes. Maybe it is much better IRL, but on the recording it is pretty bad.
    1. We tried something like this. It is annoying in real life too, but if you apply a filter to the audio that only passes the bass the effect is really good and not distracting at all.
Leave a Reply to Hack JackCancel reply
