Why Pendulums Sync Up, And Other Mysteries Explained
If you’ve ever seen fireflies flashing together at night, you’ve witnessed the glory of synchronisation. In a new video, [Veritasium] examines some of the mechanisms in nature that help create order out of chaos.
The story begins back in 1665, when [Christiaan Huygens] discovered that two pendulum clocks hanging from the same wooden beam would spontaneously synchronise over a period of time. The same principle is then demonstrated with metronomes – an experiment readily recreated in the home. Other systems that show this same eerie coordiation are then explored – from tidally locked moons orbiting around planets (like ours!), to chemical oscillators discovered by Soviet scientists during the cold war. There’s also a great explanation of the problems faced by the London Millennium Bridge, which swayed wildly under heavy foot traffic as it induced pedestrians to walk in sync.
Overall, it’s a look at some of the action behind the scenes that ties seemingly independent systems together. Learning about such things can prove useful too – it might even help you solve real world problems in your machine shop! Video after the break.
6 thoughts on “Why Pendulums Sync Up, And Other Mysteries Explained
  1. Loosely related:
    https://www.youtube.com/watch?v=Qyn64b4LNJ0
    After these 2 topics I’m thinking on which resonance effects might show up in multitasking systems, networks, …
    How can we make a task “feel” the “pressure” on the system?
    Keeping track about the own performance and adjusting its own behaviour to it?
    That may turn into a feedback loop like in walking over a bridge or as negative feedback parameter measure to prevent such.
    Ransomising retry delays after connection failures comes to my mind.
    Interesting topic… orbital and other resonances in the virtual space…
    …but currently other topics on my to do list are crying louder for attention.
    1. Steve made this in response to the Veritasium video, to dig deeper into one part that was mentioned on orbital resonance.
  2. It has long been known that two physically-close (and close in frequency) analog electronic oscillators will be “dragged” into synchronism. Not prevalent in crystal-controlled oscillators.
Leave a Reply to punkdigeratiCancel reply
