Game Boy Macro Build Retains DS Compatibility
Building a so-called “Game Boy Macro” is a great way to salvage a Nintendo DS that has a broken hinge or top screen, as the system only needs the lower display to play Game Boy Advance games. Naturally, DS games that were designed to use both screens would no longer be playable. Or at least, that’s what we thought. But as [Facelesstech] shows, it’s actually possible to play DS games on a Game Boy Macro if you do a little extra soldering.
It turns out that there are two test points on the original DS motherboard where you can pick up the signal for the top and bottom screens respectively. With just three wires and a simple switch, you can select which signal gets fed into the bottom screen in real-time with no image degradation. Now, this won’t do you any good on games that make constant use of both the top and bottom DS displays, but for many titles, the bottom screen was used for little more than a map or inventory display that you only need to glance at occasionally.
Installed screen switch. Note USB-C upgrade module.
With the ability to switch between them at will, a large number of DS games are perfectly playable with just one screen. Interestingly, the touch panel still works the same regardless of which video feed is being pipped in; so if you memorize which areas need to be touched to perform different actions, you don’t even need to flip the images. In the video below, [Facelesstech] demonstrates the concept with New Super Mario Bros, which would otherwise be unplayable as the action usually is shown on the top screen.
This hack is only possible because the two displays on the DS are identical beyond the touch overlay, which as we learned during a previous deep-dive into the technology behind this revolutionary handheld, was a trick Nintendo used to squeeze as much performance as they could out of its relatively meager 3D hardware. Unfortunately, it seems like the modification is much harder to pull off on the DS Lite, so it wouldn’t be compatible with the slick Game & Watch styled Game Boy Macro we covered recently.
9 thoughts on “Game Boy Macro Build Retains DS Compatibility
  1. I passed along my original red DS long ago, but this is exactly the sort of hack I would have been interested in. I even saw a GB Macro being sold in a used game shop last week, I love the reuse of the hardware.
    1. I tried to sell my DS but couldn’t get even $30 for it. Glad I kept it. Unless you do an IPS mod for a GBA, the DS has a really good screen for GBA games.
  2. I’ve always been on fence about this project because there aren’t a whole lot of GBA games I’m interested in (I know that might be a controversial opinion…), but being able to play at least a large chunk of the DS library on a Macro really changes things.
    Shame this technique only works on the original “fat” DS though, those screens really haven’t aged well now that most of us spend our days staring at super high res IPS panels.
    1. You could, but this mod came about for people who broke their screens or hinges. The bottom is just a larger version of the rare Gameboy Micro. So if the option is this…or throw it in the trash…
    2. I don’t see the value of doing this to an intact, working DS, but it’s a great reuse of the hardware if the top screen is no longer functional.
    3. Well, if your top screen still functions, it is dumb. If your top screen is borked, however, this mod is a lifesaver.
Leave a Reply to Kenny GCancel reply
