This is the final weekend to enter your supportive tech project in the 2021 Hackaday Prize. To goal is to find ways to make building or using electronics easier.
Accessibility is one obvious approach to this challenge. But you can also consider the example of reference designs in datasheets. Manufacturers know you don’t want to re-invent the wheel to use their switch-mode power supply so they give you information on how to lay it out on the PCB and what parts to choose. Now take that idea and run with it. This could be a modular design that takes the wizardry out of building electronic projects. But it could just as easily be a aimed at the end user — perhaps lab equipment that’s normally expensive and requires expertise to operate but you’ve reimagined it to have most of that expertise built in.
Need some more help figuring out what this is all about? Let’s look at some of the projects that have already been entered. With devices all around us that have superb cameras and dazzling screens, [Timo] realized it wouldn’t take much to turn one into an inspection microscope, which is just what’s been done with nothing more than a 3D-printed stand and a desk lamp.
[Alain] put his electronics knowledge, and the availability of cheap modules, to great use for his non-verbal son. The PECS Communication Board has a grid of sixteen images, each is a button to act as input. He makes the point that tablet apps exist for this, but durability and cost are both issues that his approach helps address.
There are already a ton of other great entries for this round of the Hackaday Prize, but it wouldn’t be complete without yours. Ten will be chosen to receive $500 each and move on to the finals with a $25,000 grand prize on the line. Start your project right now on Hackaday.io and use the left sidebar drop down menu on your project page to enter it.
You have until Monday morning when the next round begins. Good luck!
