Charge Your Apple With Apples
the full charger with gas tank and engine
When you think of ethanol, you might think of it as a type of alcohol, not alcohol itself. However, in reality, it is the primary ingredient in adult beverages. Which means humans have gotten quite good at making it, as we’ve been doing for a long time. With this in mind, [Sam Barker] decided to make ethanol out of apples to power a small engine to charge his phone.
The steps for making pure ethanol is quite similar to making alcoholic cider. A friend of [Sam’s] had an orchard and a surplus of apples, so [Sam] boiled them down and stored the mush in jugs. He added activated dry yeast to start the fermentation process. A dry lock allowed the CO2 gas that was being created to escape. Over a few weeks, the yeast converted all the sugar into ethanol and gas. In the meantime, [Sam] sourced a chainsaw and adapted the engine to run on ethanol, as ethanol needs to run richer than gasoline. The video below the break tells the story.
With his solution at just 15% ethanol, he needed to distill it to get pure ethanol for the engine to run. With a little bit of handwaving due to UK laws, [Sam] soon had a 94% ethanol solution. The next step was to use a molecular sieve, which absorbed the water but not ethanol. He secured the engine and generator to an old cutting board, and [Sam] was ready for the first test. Fine-tuning the right throttle and choke took a while, but [Sam] had it going consistently when he ran into a snag; the phone wasn’t charging. He revved the engine up, and his little charge regulator exploded. His multimeter probes were backward when he had measured the generator, and it was outputting a negative voltage. With the board swapped, the phone was charged. But [Sam] saw over 50 volts coming off the motor at times. So like most of here at Hackaday, he wanted to see how fast/high/far it could go. This ultimately fried the motor.
If you’re interested in modifying generators to suit your particular fuel needs, we have generators running on natural gas, ammonia, and even your own feet.
16 thoughts on “Charge Your Apple With Apples
  1. So many inefficiencies so much waste but it works. Bigger waste of alcohol. Loudest noise to charge a phone.
    A bicycle light generator is self limited to 300mA. AC to DC and some resistance, probably easier to rig up in a pinch without fireworks.
    50 years ago Soylent Green was set now. I like the scene where they take turns pedaling the generator for some light.
  2. Great stuff. I once met someone at a UK maker faire doing simular with 2 stroke mopeds, he was changing/adapting lots of the seals on the engines as he said ethanol was more corrosive. I wonder how long the set up in the video would survive.
  3. “The next step was to use a mechanical sieve, which absorbed the water but not ethanol”
    Molecular sieve, surely?
  4. I make ethanol from the apples in my garden too, but for drinking.
    I don’t bother washing, peeling, and boiling the apples, though. There’s natural yeast in the skins, and if you don’t kill it on the way into the demijohn, that’s more than enough to get a good drink out of it. It’s worth buying a cheap fruit press to get the juice out of the apples, though. (A kitchen food processor will do the job of scrappling the apples into a mushy pomace.)
    1. For fuel ethanol the preference is for high alcohol yeasts. It reduces the amount of water you put in and the amount you have to distill back out. Still an excellent point; Natural yeasts work for fermentation too.
      1. I’d be interested in finding out about hobby scale and inexpensive reverse osmosis membranes for reducing the energy input. i.e. sieve the water out, kinda.
        1. Actually, why ain’t those part of the process, if it’s alcohol that poisons the poor yeasties to death, having it continually sucked out as produced would keep the wee yeasties alive and make for a semi-continuous process.
      2. There are yeast strains that ferment higher and also ferment faster. 12-17% in 24-48 hours yeasts were developed in the 90’s and they’re so fast you can’t put a bubble lock on the bottle because it just toots the water out and blows it up at the ceiling.
        It makes for terrible tasting booze, like drinking wet cardboard, but boy is it fast and strong.
  5. Word of warning: partially combusted ethanol releases acetaldehyde.
    https://en.wikipedia.org/wiki/Acetaldehyde
    It’s a group 1 carsinogen and a major contributor to lung cancer and asthma, and it contributes to photochemical smog in the atmosphere, so it’s a major air pollutant. Adding ethanol to gasoline was a pretty bad idea.
  6. Why not KISS and connect apples in series (battery) to get proper voltage and multiple apple batteries in parallel to get proper current? And have they no Everclear in England?
    1. Hard to find anything over 100 proof .. ~62.5% .. apart from methylated spirits, and I hear tell that that is replaced by “meths substitute” in many hardware stores now… but that doesn’t use up waste apples.
    1. Owning a still is illegal, let alone using it. And “The Excise”- as it was known to American colonialists- not only doesn’t need a warrant to inspect your premises, they can break down walls if they think there’s something illegal behind them.
      All of which is a great pity, since there’s such an interest in small-scale beer and cider production these days that one would think that the revenue collected from micro-distilleries supported by a group of knowledgeable and approachable inspectors would be substantial.
    2. For making ethanol for a fuel you need a free federal fuel alcohol producer permit from the TTB.
      For making drinking Alcohol the requirements (and taxes) are significantly higher. State laws are a mishmash and I can’t help with those.
      I read a great hippie book on this that’s worth reading: “Alcohol, it’s a gas”. It’s probably dated now, but I’d still recommend it. It covers many other possible feedstock besides corn; that was of particular interest to me.
Leave a Reply to concretedogCancel reply
